Question about Catnapper Soother Heated Massage Power Lift Chair Recliner
Why wont my lift chair go down ? - Catnapper Soother Heated Massage Power Lift Chair Recliner
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
Tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 | Health & Beauty
Lift chair will not go up or down
Here's the manufacturer's phone #
1-800-994-3390 Reviews state that the hand controllers fail a lot and the parts department is slow.
Jul 26, 2014 | Home Meridian Comfort Lift Recliner
Chair will not go down
Most Common problem for Home Meridian Lift Chairs...........
Nov 23, 2013 | Home Meridian Comfort Lift Recliner
Can I or how can if possible return the Pride Lift Chair to normal seating position manually.Thank you.btrapp@sasktel.net
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
Dec 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
Catnapper Soother Heated Massage Power Lift Chair Recliner Logo
Top Catnapper Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Catnapper Furniture Expert? Answer questions, earn points and help others
