Question about Philips 20DV6942 20 in. TV/DVD Combo
Tv's dead WHen I try to power my tv, nothing happens. Tv was left plugged for a week in my cottage and now refuse to power up; not even the led will come on. I opened the back cover and checked the fuse inside; it is ok. The power switch seems to work since I hear the click when it is pushed down, however I did not check continuity. Now I suspect it could maybe due to some relay not closing in the power circuit. Unfortunately without a scematic it is hard to follow the parts in the tv. Any help ?
    Problem Solver:
  • 6 Answers
Check for shorted Zener in stand-by circuit , D814 C33PH, 33v Zener
Posted on Jul 27, 2008
  • 3 Answers
You need to change the opto MOC3021, together with the triac BT137 I wait and this solves your problem
Posted on Mar 01, 2008
  • jorge  luis
    jorge luis Mar 01, 2008
    another possibility is that you have in shortly the vertical circuit, Luck
55" led ,replaced the power supply a couple months ago, tv has been working properly until a week ago, now seems as though the power supply is going out again.could there be something causing this.
Hello Geoff Bowen,
Industry standard is now pretty cheesy capacitors...
(the reason not to feel persecuted until number three fails!!
but yes... if you have your set in the sun-light or poorly ventilated... any increased heat will cause the caps to fail MORE QUICKLY.
(always use a wrist band on any board you care about)
But by the time that happens you will have already figured out
to send your old boards for repair... or better...
Started your own cottage industry
(these things are popping like POP-CORN).
Even Amazon has cap "kits" and replacement boards.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 23, 2016 | Televison & Video
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
When I use the remote to turn the television on, nothing happens.
This problems happen to all LCD and Plasma tvs.In to 1 or 2 maybe 3 to 4 years old in used.The power supply board have these componnents parts call the capacitors,it will started to bulges up on it top,or puff up on it top.These capacitors are leaking gases and it dead.The tv will not power up and the LED power lite indicator start continuous flashing LED light.U know basic electronic's and soldering?Take the tv aparts where the power cord plug into it that ur power supply board.Searches all around the power supply board and it supporting boards,replaced all those dead gas leakage capacitors.Ur tv will power up normal again and work.Or Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 24, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
I don't know if this will help anyone else, but I sure hope it will. I had a similar problem with TWO of the three Sony 24" TVs I had bought together. TV#1 konked out a month ago; TV#2 messed up last week. So I called the Sony Service Center, and this very nice guy told me that a lot of times this problem occurs because the TV isn't plugged directly into the wall (most people plug theirs into a power strip/surge protector). When it happened to TV1, we hadn't been using TV2 so we just traded their locations and the "bad" one sat there waiting to be thrown out...and sat and sat and sat. Well, I was pretty hot when it happened again a month later to TV2. The service center guy told me to unplug TV2 and replug it in the wall after about 1 minute and turn it on. Nothing happened. Then he told me to plug in TV1 and turn it on. I did, reluctantly. And it actually worked!! I don't know if anyone having this problem has a week to be without their TV, but the guy said sometimes it takes up to a week of sitting to get it to work right again. So I'm waiting a few more days before I try to plug in TV2 to see if it works again, but for now, at least I've got one TV back. Here's hoping you all have the same experience. And then I guess we'll have to decide whether to plug back into a power strip (mine was actually plugged into my cable TV's DVR machine) or into the wall.
Dec 11, 2007 | Televison & Video
NO POWER
try to check the fuse first.
Aug 07, 2007 | Sylvania 6432GG 32" TV
Tv turns on, but when you turn it off it won't turn back on.
sounds like its a cold solder connection somewhere in the set or a capacitor thats bad in the power suppy.. These problems are the most dificult to troubleshoot unless they happen all the time.sorry I wish I could give you more info..
Mar 26, 2006 | Samsung TCC1340 13" TV
Philips 20DV6942 20 in. TV/DVD Combo Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
