Question about Corning Pc-320 Laboratory Stirring Hot Plate Stirrer
Need manual for Corning hot plate stirrer model pc320
Corning Pc-320 hotplate/stirrer. Where can I get a manual?
Why do you need a manual there is nothing to do. To make the stirring function work, you need a magnetic stir bar (just a Teflon coated magnet. There is a motor-powered spinning magnet under the ceramic plate.
The heater is not thermostatically controlled. It just heats more as you turn the dial more.
May 17, 2015 | Corning Pc-320 Laboratory Stirring Hot...
Need power cord for corning hot plate model#E-1310
I need a power cord for a Corning E- 1310 hot plate
Jun 26, 2013 | Kitchen Appliances - Others
What is a hot plate stirrer?
From Wikipedia: A magnetic stirrer or magnetic mixer is a laboratory device that employs a rotating magnetic field to cause a stir bar (also called "flea") immersed in a liquid to spin very quickly, thus stirring it. The rotating field may be created either by a rotating magnet or a set of stationary electromagnets, placed beneath the vessel with the liquid. Since glass does not affect a magnetic field appreciably (it is transparent to magnetism), and most chemical reactions take place in glass vessels (i.e. see beaker (glassware) or laboratory flasks), magnetic stir bars work well in glass vessels. On the other hand, the limited size of the bar means that magnetic stirrers can only be used for relatively small (under 4 liters) experiments. They also have difficulty dealing with viscous liquids or thick suspensions. For larger volumes or more viscous liquids, some sort of mechanical stirring is typically needed.
May 01, 2013 | Science & Laboratory
What are hot plates used for?
hot plates are used to heat glassware or its content. Many hot plates also have magnetic stirrers
Jan 13, 2013 | Science & Laboratory
Need a manual for VWR VMS-C7 hot plate thanks!
https://media.vwr.com/stibo/hi_res/8526649.pdf
May 11, 2012 | VWR Vms-c7 Hot Plate
Need power cord for corningware broil,bake tray Model P-54 and for the P-35-B tray Thanks
The Corning Ware P-35B bake broil tray is for use inside your oven or broiler. It can also be used inside your microwave. It is made out of the same material as regular Corning Ware bake ware and may also be used on top of the range. This is not an electrical part and should not have a connection for a cord. Corning Ware did make hot plates. Is this what you are seeking a cord for?
Oct 12, 2010 | Kitchen Ranges
How to get to stirrer on amana mvh220e microwave oven?
You don't have to do that kind of disassembly to get to the stirrer on this model.
The stirrer is located under the floor plate, which is probably ceramic and certainly fragile.
It's held in place with a rubber gasket, which you should be careful not to tear.
You can use a butter knife or putty knife to gently lift up the front of the floor plate, then it will slide forward & out.
Then you'll see the stirrer.
If the gasket is torn, it should be replaced or sealed with caulk after a thorough degreasing and cleaning.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 01, 2009 | Amana MVH220W Microwave Oven
Hot Spots in my Spacemaker Microwave Oven JVM14OH001
Okay, I see now.
That would be the "stirrer blade assembly" part number WB2X9935.
It comes as an assembly, with the stirrer blade and what looks like a coupler.
GE sells it for $98, but you can get by searching for part # WB2X9935 here for only $55.61.
Aug 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Corning Pc-320 Laboratory Stirring Hot Plate Stirrer Logo
131 people viewed this question
Top Corning Science & Laboratory Experts
William McMath
ray gallant
Are you a Corning Science and Laboratory Expert? Answer questions, earn points and help others
