Change bios settings to accept ram without ecc
I want to add ram to 1gb but my computer needs ram DDR2 4200PC 533 ECC which is not found easly so i want to change bios settings to accept other DDR2 RAMS
  • 413 Answers
Actually there is no such fix available as mother board in complete has different component that works in sync and changing bios wont be of much help instead try compatibility chcek and update only the most needed hardware
Posted on May 08, 2009
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Would this particular RAM work with my Dell Dimension 2400? http://cgi.ebay.com/KINGSTON-1GB-DDR-PC2700-ECC-REG-KVR333X72RC25-1G-RAM-/380226148054?pt=LH_DefaultDomain_0&hash=item58873e96d6
According to the Dell specification found here:
http://support.euro.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm#1105481
your PC does not support registered ECC RAM.
Most desktop PCs use unbuffered RAM. Registered ECC (Error Checking and Correcting) is a special type of RAM mostly used in servers.
Unbuffered RAM is faster than ECC RAM and is usually cheaper.
To find RAM that is compatible with your PC try the memory configuration tool at www.crucial.com
Please rate my answer is this was helpful.
Many thanks,
Chris
Mar 05, 2011 | Dell Dimension 2400 PC Desktop
Can the bios support using ecc memory to run as non ecc?
hi simple answer no, this feature is designed for that specific reason, if you have ECC ram you have to enable the ECC support in the bios, ECC ram has a different timing and ways of using the data flow, it is much slower than non ECC ram and uses more voltage, that's why most people prefer normal SD ram or DDR ram, you can however use these in *********** board if you turn the ECC support off, so long as your board will take the specific ram....hope this helps
Mar 15, 2010 | Compaq Computers & Internet
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
I have a Gigabyte-GA-8SIMLNF motherboard and recently bought 2gb (2*1gb)of pc2100 DDR and am getting the no ram beep,it is labeled ecc ramwill this not work?
Your motherboard does not support ECC RAM. You'll have to buy a PC2100 nonECC DDR RAM. Also, it supports a maximum of 2 GB RAM, i.e; 2 RAMs each of 1GB in each slot.
Hope this answers your query. Thanks.
Jul 22, 2009 | Intel Motherboard
Not upgrading 1gb ram to asus p5vdc-mx
yeap its the wrong memory.
max mem is 2GB DDR2 533/400 non-ECC, 2 x 184-pin DIMM
or you can use. 2GB DDR 400/333/266 non-ECC,
Note, you cant use both DDR2 and DDR in the same time. so set both memory stick as same type.
so if you set 2x1GB DDR2 533 you get the optimized speed.
hope it helps.
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Hello! can i use two 1GB DDR2-800 ram in my motherboard INTEL D102GGC2
Your motherboard takes 533 or 400 DDR2 SDRAM Non-ECC DIMMs.
If your memory is DDR2 Non-ECC it will fit but only work at 533.
Jun 17, 2009 | Intel D102GGC2 Motherboard
No manual - want to install SNP J0202C/512 myself
This (4th)link should answer all your questions. If you enter your service tag number Dell can help more You can also get help from where you buy the memory it's not that hard..I like the first link to find out what memory to buy. I like the second link for pricing. Please rate me mysleuth
http://www.memory-up.com/default.aspx
http://dealnews.com/memory/
http://www.ask.com/web?q=how+to+install+ram&search=search&qsrc=0&o=0&l=dir
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs&SystemID=DIM_PNT_P4_4550
Apr 08, 2009 | Dell Dimension 4550 PC Desktop
Ecc
ecc RAM are better RAM install it
Nov 27, 2008 | HP Compaq Evo n610c Notebook
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
