Question about Watches
I need the instructions for a Sonic watch
I need the instructions for a Sonic analog and digital watch COMBINED in one. I believe it is a B10 model.
SOURCE: Time's do not match
if you still need to do this email me on kfsmail@aol.com
Posted on Jun 24, 2007
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
SOURCE: Adidas watch
Troubles you to help the solution to look for adidas the adx156 instruction for use, thanks!
Posted on Feb 27, 2008
SOURCE: Instruction Manual for Fossil Watch
go to fossil .com and click on customer service that is where all manuals are hope this helps
Posted on May 14, 2008
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
I need a owners instruction manual
Hi try this area of FIXYA,--->http://www.fixya.com/support/p750441-timex_indiglo_analog_watch/manual-25620
It has instructions for Digital and Analog versions of this watch
Hope this helps
RJ
Jul 10, 2011 | Timex Indiglo Analog Watch
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
Resetting the Analog time on my Citizens Stars and Stripes Watch
I couldn't find find your model on their web site but if all else fails, you could go to "www.citizen-signature.com/#/support", where you will be able to request instructions.
Mar 11, 2010 | Watches
Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
May 26, 2009 | Watches
Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Mar 14, 2009 | Seiko 0512037FA Wrist Watch
Instructions for adi analog/digital dive watch
Please try these links
I dont know the model but you can find the instructins for similar to your model
Good Luck
http://bulova.com/service/servicecenter.aspx
http://bulova.com/dynamic_repository/instructions/558.pdf
Dec 25, 2008 | Bulova Watch
Problem Syncronizing the Analog & Digital
Hi ...
Oh yes, a problem which I also had :) easy to overlook this moment - even in the original instructions. Very accurate description of all the features of Citizen Ana Digi Temp - including how to set the time - and Synchronize Analog and Digital watch, you will find on
CITIZEN Ana Digi Temp
Best Regards
Dec 06, 2008 | Citizen Blue Angels Skyhawk Watch
Watches Logo
382 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
