Question about Emerson Mw8997b Microwave Ovens
Turntable quit turning
The turntable wont turn. I want to fix it but not sure how to take it apart
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
Turntable does not turn (work). model:JVM3660SD001
have you check if the unit has the power... & also check if all the settings was made..
Jun 13, 2008 | GE Microwave Ovens
Microwave turntable wont turn
Hi - Possibilities of the turntable not spinning are either it is turned off, damaged or the support itself is damaged as well. Confirm that the power supply is not faulty or defective. Contact a professional to move forward accurately.
Oct 30, 2012 | Frigidaire FMV157GM Microwave Oven
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
Smh9187 turntable quit turning
1) the cabinet need to open for repair the small motor can be defective.test it see the diagram
2) test the plastic drive coupling+ring and roller assembly if is working properly , test and fix it.
see the diagrams and pictorial
God bless you
Jul 17, 2012 | Samsung SMH9187 Microwave Oven
I have a GE spacemaker XL over the stove microwave oven. Its 10 years old. The turntable quit turning. If I take the glass turntable off and put a glass of water inside, the motor will turn - sometimes...
This is a common problem in many brands, you have proved the AC voltage to the motor is fine, if there had a been an issue the voltage would have dropped while in operation causing a load on the power supply, since there was no change in the off/on stage it proves the motor is the problem and must be replaced to resolve the issue.
Jun 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
Whirlpool MH1150XMB
there is a motor under the turn table that spins that tray.now some more expensive units would allow you to turn off the turn table if user wanted to,so check that out .but if not and its under warenty call a sears or any servicer that repairs you brand under warenty
Jan 25, 2009 | Magic Chef CMV1000B Microwave Oven
Turntable will not turn on Microwave
It's usually probably a failed turntable motor, but you should double-check the coupler, too.
We actually have the complete service & repair manual for this model at our site: http://www.microwavedisplay.cm/r930ak_aw_sm.pdf
You can order a new motor via Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 10, 2008 | Microwave Ovens
Turntable repair? GE Profile model JVM1660BB
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Mw8997b Microwave Ovens Logo
44 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
