Question about Microwave Ovens
Remove broken lightbulb - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Nov 27, 2013
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Inside lightbulb went out
look at the top. there may be an access thingy you can remove to get to the lightbulb. replace the lightbulb with suitable replacement. problem solved.
Feb 16, 2014 | GE Microwave Ovens
The inside lightbulb went out how do we replace it?
open the microwave. If there is a removable panel on the top, remove it and replace the lightbulb.
Feb 16, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Lg lmh2016st microwave shorted out after changing lightbulb now doesn't work
We see and repair this a lot. The problem is on the controller assembly.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 01, 2013 | LG LMH2016ST
Cuisinart microwave CMW-100. How do I change the lightbulb?
You need to remove the cover from the oven. Pull the plug first! Remove the Philips Screws. There are two special screws that are meant to prevent your proceeding further. No standard driver will fit these screws. You can remove them with small pliers gripping the outer edge of the screw and turning counter clockwise. If you are not familiar with capacitors, get somebody who is familiar. The light socket snaps in. Unsnap it. The lamp is taped to the socket with cellophane tape. I have never removed the lamp nor do I know the number. Do not plug in the oven with out the cover!!!!!
Jun 30, 2012 | Cuisinart CMW-100 Microwave Oven
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
I am having a problem installing the cooktop light on my Bosch microwave. It looks as thought the light "blew" and now I can't get the broken lightbulb out of the socket.
It's probably attached with hot glue to keep it from getting loose due to heat or vibration.
I would be sure it's unplugged, then use needle-nosed pliers to remove the leftover base from the socket.
May 19, 2008 | Bosch Microwave Ovens
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
