Question about LG Heating & Cooling
Don't understand outdoor self diagnosis code
Hi everyone My lg a4uw306fa0 compressor doesn't start.Fans are ok,i can see them turning, i can hear the little music with my indoor unit but the compressor doesn't start. On the pcb of the outside unit,indoor units all off, the green light is on (no blinking) and the red light is on and then blinking twice (very very fast, i made a video to be sure it's twice and not three times). I check all error codes in the service manual, but this one is not listed. Can someone help me? Thanks in advance
    Master:
  • 613 Answers
This sounds like a fault with the inverter or the compressor motor itself,
Posted on Dec 08, 2013
4 Suggested Answers
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
Sir, LG package unit , error code CH21 its was start but after 5 minutes turn of its self,??kindly help me,?
Sorry but must replace the pcboard of outdoor unit and maybe the compressor too. It isn’t worth to fix it.
Nov 09, 2017 | LG Heating & Cooling
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Tip
Understanding Air Conditioner Electrical problems is not as hard as you can make...
Air Conditioners are broken down into two electrical systems, though they work together1. Low voltage control unit 24-28 volt control unit like thermostat and other switches and relays( also feeds compressor contactor,reversing valve, and defrost board on heat pumps)on the outdoor condensing unit .When there is no power to the thermostat,it cannot turn on the indoor fan or any other load (indoor or outdoor). In this case, first confirm there is power available (closed breaker,closed disconnect) If you have power the fan on manual switch on the thermostat should be able to turn on the indoor fan.If it doesn't, then your control voltage is most likely lost. check the transformer and 3 amp fuse in the air handler .2.The high voltage components are your compressor and your fans, both indoors and outdoors.High voltage 240 volt loads are controlled by the 24-28 volt control voltage.3. Remember, a thermostat is just a big on/off switch.4.Be careful and always play it safe when working around energized circuits5. Leave it to the pros, especially if you're inexperienced or nervous about electricity
on Aug 22, 2013 | Heating & Cooling
Hi , have just acquired a 6yr old LG GR-332SF fridge , has a major power issue . Trips circuit breaker when turned on . Looks ok , checked wiring , though removed defrost timer and saw faint blackening on...
Most likely the compressor is drawing excessive load current. It is about the only part inside the unit that can do so. Of course, you may have some shorted wiring inside somewhere. An electrical diagnosis would reveal the cause quickly. Find someone who can use a multimeter with skill.
Jan 13, 2015 | LG Refrigerators
LG Fridge LSC26945TT compressor getting to hot and not cooling
if it's not cooling unplug it so you don't damage the compressor,hopefully you just have a bad overload and relay,it's plugged into the side of the compressor,with the machine unplugged remove the bottom back panel,look at the compressor,remove the cover on the side of compressor and remove the start device or ptc assy. call your local parts store and give them the model number and buy a new start device for your machine.if you can hear a clicking sound every once and a while and the compressor is hot change this out first,if it still doesn't start then you have a bad compressor and will be in the market for a new fridge if the compressor is running take everything out of the freezer,remove the back inside wall of the freezer and check the evap coil,if the coil is all iced up you have a defrost problem,if the evap coil doesn't have an even frost pattern covering the whole coil you have a freon leak.if you have a freon leak you'll have to replace the fridge..hope this helps
Jul 04, 2012 | LG Refrigerators
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
My Amana AAC101SRA doesn't cool like it used to. We have cleaned the filter, but that doesn't seem to help. Should we call a repairman or think about getting another unit?
Is the outdoor coil blocked? Is the outdoor coil clean? Is the compressor running when you start unit. When you turn unit off after running it can you hear a hissing sound from within?
Aug 02, 2011 | Amana High Efficiency AAC101SRA Air...
Fan motor will not come on unless it is connected to the battery
motor fan motors are connected in line to a heat sensor, they only come on when that sensor says its ok to do so,, check the sensor , giving it a direct 12 volts is by passing that sensor
Jul 01, 2011 | Pontiac Sunfire Cars & Trucks
When switched on it runs for few minutes and then switch and displays error code E3
Hi Perhaps after you switch the AC on all that is running in the first few minutes is the indoor fan. Be aware that all AC's have a start delay on the compressor as a protection device for when the operator is having a little fiddle with the controls. The delay is usually 3 to 4 minutes and occurs every time the compressor is stopped and goes to restart. The error code probably occurs when the outdoor unit goes to fire up. The problem may be a number of things. I assume that you dont have a list of fault codes, so here are a few things to look for. 1) Is the unit 3 phase? If so make sure you have all phases supplied. If that is OK check the outdoor fan operation and capacitors. 2) If the system is single phase, again check the operation of all fans and capacitors, 3) If they are ok check that the compressor actually runs. It may only hum but not spin up.. If it only hums, the capacitors may be crook or compessor jammed. If the compressor seems to be dead, ie: no response, no humming, no turning. I guess it will cost you, so call a serviceman. Again much depends on the type and model and the problems may be simple or extensive, If you are not trade qualified or experienced keeping your little fingers out of the thingo would be a real good move. However a good pair of ears can tell you much. Good luck
Feb 23, 2011 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
172 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
