Question about Sony STR-D790
Stop working, will not turn on, only indication light is on. It was on for 24 hrs and was hot on the top.
Sidebyside kenmore works great for 12 hr. then seems to go into defrost mode and won't cool unless i unplug for 6 to 8 hrs plug it back in and it works fine for 24 hrs then repeats
Larry I tried to write the solution here but it would not send. Click Here=> Kenmore Appliance Model Number Locator and examples Your solution is at top and center of that web page. Let me know if helpful or if you have more questions, Thank You, Sea Breeze
Nov 16, 2011 | Refrigerators
Just brought a second hand freezer for garage. It worked at the house but when I brought it back home and plugged it in it didn't get cold I had a green light on and a red hazard light on. Should I have...
The green light means it has power . The red light means the temp is not satisfactory . If the freezer was laid on its side anytime and did not sit for 24 hrs before plugging it in , then it's no good anymore due to compressor pumping solid oil into the lines instead of refrigerant . The oil causes restrictions not allowing the refrigerant to flow .
Sep 26, 2010 | Refrigerators
Dual-switch controller was installed by electrician 1 - 2 yrs ago, working fine (controlling ceiling fan with lamp). This week, spontaneously, green indicator lights on lamp (top switch) cycle up and down,...
Sounds like it needs to be repgramed, but it may not be in the switch, maybe in the lamp/fan receiver (sounds like the wireless one), if this is the wired version, you may have to check all connections to make sure they didn't come loose.
Jun 25, 2010 | Lutron Maestro MultiLocation Fan Control...
New season start up probnlems.
Have you given it 24-48 hrs to cool? Coils at rear will start to get hot at top, and slowly work there way down.
Yes, 24-48 hrs upside down, then same right side up before turning on, has been known to buy you some time.
May 20, 2010 | Dometic RM2652 Refrigerator
My voyager wont start it seems the alarm has stuck on , when i turn key nothing new battery fitted ,led light for alarm does not flash anymore /gear/milage lights do not come on ,i have taken battery off...
This may sound a bit simple but check the starter solenoid function by running an external wire to the thin wire terminal from the positive post on the battery.
If the starter does nothing then the starter is bad.
What your describing is a typical solenoid / starter problem. Given the car is now 10 year old, it is quite possible that either the solenoid or starter has failed.
Thanks for using FixYa!
Kelly
Feb 15, 2010 | 2000 Chrysler Grand Voyager
Charging indicator does not turn off after about
i m afraid the charging system of the phone is faulty. make sure with the manual that it is supposed to go off. i think u should take it back to the place u bought it from and seek their help...i hope it helps..
Oct 03, 2009 | Uniden Cordless Phone
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony STR-D790 Logo
18 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
