Question about Frigidaire Kitchen Ranges
Oven won't heat like i asked
I have a black range set but when I was making bread rolls, the oven won't heat the way I want it to be, I even set it to 500 degrees and no dice, I might need some help, it's an old set and it just has 6 button layout with a numeral lcd display... I got a turkey to make... P.S. The buttons are just Up and Down buttons, a clear (off) button, clock button, Timer(on/off), Broil and Bake buttons... How do I work those buttons to make a turkey...
  • 2,113 Answers
It seems like you need a new thermostat
Posted on Nov 26, 2013
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 23 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Posted on Jan 27, 2008
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
siawolf
  • 749 Answers
SOURCE: Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Posted on Oct 15, 2008
How do you use proofed feature
If I understand correctly Carol, you want to know about the 'prove' feature on your oven?
In bread making the proving part of the process is where low heat is makes the bread dough rise. It is a barely warm setting just about blood heat. It makes the yeast release carbon dioxide bubbles which makes the bread rise.
Nov 18, 2015 | GE PB910TPCC Profile Freestanding Electric...
At what time can I remove the paddle before my B&D breadmaker bakes the loaf?
The Use and Care Manual for your Black & Decker B2250 All-In-One Automatic Breadmaker can be dowloaded in PDF from the following link:
http://useandcaremanuals.com/pdf/B220,B2250984.pdf
Follow a recipe similar to that for Dinner Rolls on Page 19 where you would use the Dough Setting to allow the dough to be removed for shaping and baking in your regular oven.
May 18, 2012 | Black & Decker Bread Machine
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
WHAT I NEED TO DO TO MAKE OVEN HEAT UP
can you see the glow inside the bottom of the oven?if you can then your bake ignitor may be bad.
Nov 05, 2008 | Frigidaire FEF355 Electric Kitchen Range
Oven cleaning
There is a lever just under the cook top and above the oven door with a black handle. You need to move the lever all the way to the right. This locks/seals the door and closes the oven vent so your kitchen doesn't get smokey! Once you do this the oven clean light will stop flashing and the oven will heat up.
Mar 28, 2008 | GE Spectra JBP84SHSS Electric Kitchen...
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
54 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
