Question about Frigidaire FEF336BC Electric Kitchen Range
Burner control not working
Burner will not shut off stays on high
  • Official Brand Answer
  • 4,342 Answers
Hello Tom, thank you for your post!
I understand the burners on your Frigidaire range, FEF336BC, continue to stay on. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately ten minutes and then turn on your range. If these troubleshooting steps prove ineffective, you may wish to contact a professional as your range may possibly have a potential wiring failure, faulty EOC (electronic oven control) or burners.
Posted on Dec 02, 2013
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Burners turn on for 10 sec and shut off
going out on safety. either high limit or failure to detect flame.
Dec 14, 2013 | Ruud Central System Air Conditioner
Range top front burner will not shut off, stays on high, back burner up button does not work and timer does not work. Even though it was fixed in Feb of this year LG will not fix it again
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
Jun 30, 2010 | LG LRE30755 Electric Kitchen Range
The heater heats up, the blower comes on for a minute then goes off, and continues to cycle like this
Good Morning, So, you say the heater does heat up, the fan will cycle on and shuts back down in a minute, and continues to cycle this way. A few things that will cause this. But let me ask this first, does the burners stay on through this short cycling of fan? Let me know if we don't solve it before that. I don't know if you're t-stat is programmable or a mechanical? Anyway, you have what they call a heat anticipator on stats which will cycle unit on and off like this if they have burned out. If it is a mechanical (mercury switch) type, pull the cover and you will see a small dial with numbers and a arrow on it. Set it to .4 and if its programmable, you will have to go into the program to do this. Normally it is set at factory to .4 amps and the setting varies with the amps on the gas valve as they should match. I assume you have been there for sometime and this problem has just started.I wish I knew if the burners were shutting off when the fan cycles off? This would be helpful. If the burners stay on because the fan is only off for a short time, the high Limit switch is good, because when the burners are on, and the fan comes on and shuts off and stays off, the unit will open the contacts on the high limit and shut burners off for safety. I would say that the combination fan control is sticking or failing causing your fan to short cycle. Only, if this is an older furnace though. If it is a newer one with the electronic pilot ignitor, the main control board is you're problem and will need R & Ring. Please get back to me and give me the information I have mentioned, as name, model #, serial #, and age or if it is eletronic pilot or a standing pilot(on all the time) this will help to solve this. Also, what stat you have.Try the things I mentioned, but please get back to me so we can solve you're problem. Thank you, and Sincerely,
Shastalaker7
Nov 21, 2009 | Heating & Cooling
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Cooktop burner will be dim and red automatically
when you set a cook top burner to high then it should stay on until the "thermal" limit shuts it off. then the burner will stop glowing. if you dont put a burner on the top, the burner sensor will shut of on the thermal safety.
it is normal but what you need to check is if you pans are flat on the bottom. a bow inwards or outwards will cause the thermal to shut the burner off. the pan needs to "draw" the heat out of the top and allow the burner to operate properly.
most of the time the pans a warped causing the burner to cycle on the limit and then not heat as well as it could with a "flat pan"
Jan 22, 2009 | GE JBP66 Electric Kitchen Range
Element does doesn't switch off.
What your going to have to do is replace the infinate control for that burner. ( thats the control you turn to sw it from high to low heat )
good luck
Jan 07, 2009 | Kenmore 96212 / 96214 / 96219 Electric...
Uncontrollable Burner
It is the infinite switch (burner switch) located in the console,.
Oct 16, 2007 | Whirlpool RF364 Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
89 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
