Question about Pitco Frialator 35CS Deep Fryer
Pilot light will not stay lit once pilot button is not depressed. Replaced thermopile already. Any suggestions? Also don't have milivolt detector. Thanks
What would be the most likely cause of the malfunction if the thermopile is new?
  • Pitco Frialator Expert
  • 684 Answers
Hi there.
Check the wiring, loose wiring terminals can disrupt the current going to gas valve.
Try also to connect jumper wire across the hi limit terminals, if this do the trick, replace the hi limit device before operating the fryer.
Lastly, the gas valve may be defective.
Regards.
Posted on Dec 04, 2013
4 Suggested Answers
SOURCE: Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Posted on Feb 13, 2008
SOURCE: pitco fryer pilot out
the problem is the thermocouple , and not the gas valve or thermopile
Posted on Feb 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: Pitco 35C+ fryer. Pilot lights fine; main burner
Its a simple design. If the thermophile does the work of powering the fryer control. Do you have a good pilot flame? If the pilot flame ain't good enough then the millivolts won't be enough to operate the solenoid on the gas valve. Most folks replace both the pilot and thermophile on these fryers since the grease makes such a mess of everything. If the pilot generator is fine then the gas valve is next.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 01, 2011
Just replaced thermopile generator and pilot will not stay lit
Check the new thermopile with a millivolt meter and make sure it has the correct output not connected to the gas valve.If it does,then the gas valve is defective.Make sure to test ONLY the thermopile.If it does not generate enough millivolts the gas valve will not open.If the piliot is dirty it will not generate enough heat for the thermopile.Make sure you have a good,strong,blue flame at the pilot.You said the piliot will not stay lit?If not then start by blowing air back through the piliot where the flame comes out with compressed air.hopefully that will clean it well enough.If not you may have to take the pilot tubing loose from the valve and use compressed air to clean it.Make sure when you reconnect the tubing to the valve USE FINGERS ONLY to start tyubing or you may crossthread the tubing....and thats NOT a good thing.Good Luck.
Jan 16, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on gas fireplace will not remain lit
check that you have thermopile connections are right at valve and that the flame is hitting both thermopile and thermocouple good. pilot falme may be blue but is it strong? a strong pilot has flame completely hitting both safety's. if pilot is small check pilot orifice inside pilot hood, a quick fix which may work is put vacuum over pilot hood and **** out any dust in there, just be gentle...
Feb 06, 2010 | Ovens
Cozy Wall Gas Furnace Pilot won't stay lit
Hi, if you have replaced the thermocouple or thermopile generator, and it keeps going out, you will need to replace the gas valve. That's all it can be is the milivolt coil on the valve, trust me. I have been through this many times.
Sincerely,
Shastalaker7
Dec 29, 2009 | Heating & Cooling
Pilot wont stay lit
If it will not stay lit from a cold start, you will need a thermopile. You can check it if you have a DC meter that will test milivolts. It should be putting out between 300 and 500. If it will not stay lit after the pot gets hot, you will most likely need a high limit. Try pushing the red button below the thermostat. This will reset the high limit.
Oct 04, 2009 | Pitco Frialator 45C Deep Fryer
use a torch to simulate pilot flame and read milivolt. if ok then make sure pilot flame is fully contacting thermopile. also make sure thermopile wiring connections are clean and secure.
Jul 16, 2009 | Imperial IFS40 Deep Fryer
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pitco Frialator 35CS Deep Fryer Logo
100 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
