Question about Toro Garden
Bad rear drive chain
Want to change the drive chain rear
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
On what ??? model # serial # brand, type of equipment... Only then can you get a helpful answer.
Posted on Nov 27, 2013
Rear drive left chain breaking on a regular basis. can,t find any reason for this . any ideas
there are two reasons for chain breakages . One is chain tension too tight or too loose and second is the sprocket teeth are badly worn and actually trying to get our of mesh. This will be amplified if the chain is too tight.
Oct 26, 2013 | Air Tools & Compressors
Tip
Changing your drive chain
When changing the chain on your motorcycle, don't just pull the old one out and then remove the covers to thread the new one back on. With the transmission in neutral and the rear wheel off the floor, break the old chain, then using a master link attach the new chain to the old one, pull the old one around the countershaft sprocket and bcak until you can grab the new chain. Disconnect the old chain and you are ready to connect the ends of your new chain.
on Dec 20, 2009 | Motorcycles
Transfer case noise
wow eral vague stuff to work with.. do you plow?? off road? or did truck used to do this.... basicaly u got input shaft from ****** .thru clutch pack to gear, output to rear drive . gear linked to front gear by chain. chain will strech over time and slap inside case if bad enuff . but will sound like clunk if just worn when you engage it .parts are availible but cheaper and faster to get low mileage one from wreckers and change out .
Feb 01, 2012 | Ford Explorer Cars & Trucks
I have aligned the chain (every couple of months I have to tighten the chain , does it stretch that much!) and when I'm driving the chain noise is louder than the engine . Is this normal??
Raise the rear wheel off of the ground. Spin the rear wheel by hand while running the chain over your hand (wear a surgical glove or use a rag). If the chain gets tight and then loose it has stretched and needs to be replaced. If it is an older Honda (70's), unbolt the rear shocks and see if the swing arm moves from side to side. If this is the case you also need new swing arm bushings. Another sign that the swing arm bushings are bad is if the chain is banging against the swing arm while you are driving down the road.
Jul 10, 2011 | Honda CB 350 F1 Motorcycles
Crackling sound in the chains while driving and something sound like a tambourine somewhere in the rear brake.tnx
It sounds like the bike needs a new chain and probably new front and rear sprockets as well. The sprocket teeth should have a rounded blunt end. Do the replacement of chain and sprockets and then see if the tambourine has gone away. If not, I would dissasemble the rear wheel and brake for inspection. Loose or broken parts, wheel bearings gone bad or brake assembly problems may be present. Please rate my answer. tombones49_195.gif
Jun 23, 2011 | kawasaki ZX-12R Motorcycles
Clicking sound from rear wheel
If shaft drive, check that the bolts are tight on driveshaft housing and also look for oil leak there.
Check/ Change rear gear oil. Tighten loose bolts
If chain driven, check/ adjust chain tension, a loose chain will make noise.
if chain is dirty it will make noise.
Other than that the only thing i can think of is you have a nail in your tire and your hearing it hit the road everytime it goes around
Dec 03, 2010 | 2007 Triumph Rocket III
The chain keeps coming off.why?
Chains must not have too much slack in them. There should be about 1/2" (12mm) of vertical movement on the slack side.
It could be your have a worn out chain.. Look at the drive pinion. The teeth should have a flat top and both faces of the teeth should have the same profile. If the sprocket is very worn, the teeth become pointed and the chain does not sit correctly on the drive chain wheel on the rear wheel, (i.e. there is a gap between the chain and the inside edge of the driven sprocket.
If you change your sprockets, change the chain also (you must do this as the chain will also be very worn).
Mar 21, 2010 | 2002 Suzuki GZ 125 Marauder
Snow chains on front or rear tires?
the chains should go on the traction wheels .
FWD (front wheel drive ) chains on front wheels
RWD (rear wheel drive ) chains on rear wheels
Feb 16, 2010 | 2007 Toyota Sienna
Popping skipping chain
how long have you had the chain on your bike? it may be worn (or your rear cassette may be) if skipping is occurring. have you attempted to adjust your shifters as well?
May 01, 2009 | Cycling
Can a motorcycle cam chain be installed without seperating the crankcase.its a 1983 v45 interceptor rear camshaft chain.
No not unless you split the chain(not reccomended),if your changeing the chain i would suggest new chain tensioners frt and rear cyl. they where known to go bad,i replaced mine in my interceptor and my v65 magna.
Apr 07, 2009 | 1984 Honda VF 750 S
Garden Logo
52 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
