Logik instructions Please can u tell me if the logik l60chdg13 cooker hood just fixes to wall or does it need a pipe to the outside x
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: venting cooker hood to outside
Yes you may.
Please rate
Posted on Jan 22, 2009
  • 8909 Answers
SOURCE: how do i fix a
That should come with a drawing to cut out, sometimes the box itself will have that on, and one places it on the wall to mark screw holes for fixing.
It will run, as it is only a fan and a light buld, from the cooker switched outlet on the cooker point, or a fused outlet from a spur.
If you are unsure, get a qualified electrician to wire it in for you!
Posted on Jan 15, 2011
SOURCE: no ducting pipe inside the cooker hood chimney what do i need to duct outside
Depends...does the vent access attic?...if so...attach vent material from hood and penitrate roof with roof kit....at lowes
Posted on Dec 09, 2011
Draft from Cooker Hood
Grease build up could be causing the shutters to stick, There is no way around the issue of inspection. Just make sure the power is off.
Dec 23, 2013 | Kitchen Ranges
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
No ducting pipe inside the cooker hood chimney what do i need to duct outside
Dec 09, 2011 | Kitchen Ranges
How do i fix a LOGIK L90CHDG10 90cm Cooker Hood to the wall and what are the power requirements thanx
Jan 15, 2011 | Microwave Ovens
I would like to put my cook top on an island in the centre of my kitchen how would i vent down thru a crawl space???
Get a downdraft cook top and drill a hole. Then run the piping to the outside wall of the house and drill again and run the piping thru to the outside. They make outside wall vents like dryer vents only bigger to accommodate the bigger vent pipe. Happy crawling. It will look and work great if you get a good stove. Do your research.
Sep 01, 2010 | Electrolux Icon Downdraft Ventilation...
Internal cooker hood
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Kitchen Ranges
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
