How do i make the text larger on my screen - Computers & Internet
How do I make font larger?
You can make font larger by following the instructions mentioned below:
If you are using Windows 7:
1. Click "Start" and then, click "Control Panel"
2. Navigate to "Appearance and Personalization" and then, click "Adjust Screen Resolution"
3. Choose one of the following:
  • "Smaller - 100% (default). This keeps text and other items at normal size.
  • Medium - 125%. This sets text and other items to 125% of normal size.
  • Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
4. Click "Apply"
Close all the programs and log off of Windows. The changes will take effect the next time you log into Windows.
The following link can be helpful:
http://windows.microsoft.com/en-us/windows7/make-the-text-on-your-screen-larger-or-smaller?v=t
If you are using Windows 8.1, refer to the following link:
http://windows.microsoft.com/en-US/windows-8/make-text-screen-larger-smaller/?v=t
If you are using Windows Vista, refer to the following link:
http://windows.microsoft.com/en-us/windows-vista/Make-the-text-on-your-screen-larger-or-smaller?v=t
GuruAid.com
Dec 30, 2014 | Computers & Internet
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
Jun 01, 2014 | Computers & Internet
How do i make the type larger i can hardly read it
If you have Windows 7 or Vista you can do this:
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Choose one of the following:
    • Smaller - 100% (default). This keeps text and other items at normal size.
  3. Click Apply.
May 25, 2014 | Computers & Internet
How do I change the desktop text, icons and bars back to 100% from 500% in Windows 8.1?
Hi Cindy
You have set a customer DPI scale for your display.
Right Click on desktop
Choose "Screen Resolution"
Click on link that says "Make Text and other items larger or smaller"
Click on link that says "Set custom text size (DPI)"
Adjust the scale back to 100%
Apply the changes and all should be well.
Regards
Andrew
Make the text on your screen larger or smaller Microsoft Windows Help
May 18, 2014 | Acer Aspire Computers & Internet
How to change text size
please clarify; what kind of operating system your using? text size of what? application software like word or Computer screen display? for windows screen text you can enlarge by entering control panel-appearance and personalization for win7&win8 - display make item small or larger or by changing screen resolution
May 01, 2014 | HP Mini 1000 Netbook
The letters are to small and pictures too,i need to zoomout alittle bit..
This solution is for windows 7
To make the text on your screen larger or smaller
Open Screen Resolution by clicking the the Start button, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
Click Apply.
To see the change, close all of your programs and then log off of Windows. This change will take effect the next time you log on.
Sep 06, 2011 | Computers & Internet
Hot to make ares text bigger
right click anywhere on your screen and left click properties. This will take you to your screen display. You will see a lever with a number range. You can change to a higher resolution. If it's in internet explorer, go to view at the top, then text size and choose large or larger, etc. In a program such as word, you'll see some numbers at the top ext to B U and I. You can choose a larger size there.
Mar 08, 2010 | Ultra Computers & Internet
Print too small on computer screen
In the Menu bar, click View, then Text Size and select larger text.
You can also make a web page larger by pressing CTRL and + at the same time.
You can reset the monitor display in Control Panel, Appearance and Themes, Display, Settings. Adjust the screen resolution to match the shape and size of your monitor
Nov 11, 2009 | Compaq Computers & Internet
Tiny screen text
If your browser is Internet Explorer, goto the menu item view and click then to font size , and chane the size to a larger font.
Apr 12, 2008 | ViewSonic VA1703wb Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
