Bosch wfk 2801
Tripping the fuse as soon as it's switched on, even when switched off at the socket. Plug has to be removed before circuit will reset.
    Genius:
  • 1,198 Answers
You've got a major short circuit there. Start with the cord, searching for the damage. Check the schematic, to see what is connected when the machine is off, it won' t be much.
Posted on Nov 27, 2013
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
Buffalo12980
  • 625 Answers
SOURCE: Bosch Washing Machine
A washer should not be plugged into a gfci device. It should use a dedicated circuit just for the washer off a standard duty circuit breaker or time delay fusetron fuse. In most washers that are top loading, a diaphragm switch operates the start circuitry for the washer [ timer ] as water goes into the tub, a positive pressure acts on the diaphragm and closes a set of contacts connected to the timer that operates the several contacts for the motor and transmission. the only place there might be power is on the spade connectors on the motor, the timer, the water switch, the door lid switch. Now, if the motor is sooo old that the insulation breaks down, it will develop a fault to ground and charge the shell of the appliance to 120 volts. This is a hazard to you the user. If you have the technical knowledge get a meter and check the motor leads to equipment ground. If the meter deflects full scale on the RX1 setting you have a problem with a winding to ground short. Replace the motor. Another problem is you might have a frozen bearing which causes the motor current to shoot up, tripping a breaker or blowing a fuse. remove any belts and try spinning the motor pulley by hand to see if it is bound up. try rotating the pulley on the transmission to see IF it is bound up, do the same with the pump. if any of these things are difficult to rotate it may be the prime source of your problem. change the pump, replace the transmission bearing or work inside the transmission may be necessary. motor bearings are press fitted on the motor shaft.
Posted on Sep 15, 2007
barkencoa
  • 3463 Answers
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 1531 Answers
SOURCE: Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Posted on Sep 16, 2009
Hi my samsung fridge/freezer suddenly started to trip my electricity,I changed the plug but still is tripping the electricity,also checked the socket,definitly the fridge
First you must isolate the problem. remove the rear service cover(unit unplugged) disconnect the wire plug to the compressor. replug the fridge. If the circuit doesn't trip ,then the compressor or relay is defective.
May 04, 2018 | Samsung Refrigerators
Convection electric heater by " de long hi" Heater does not turn on when pres the "power on" switch
fuse in plug often blows. but delhonghi are weird. i've got one that trips unless i put an rcd plug between it and the wall socket to stop it tripping. is yours tripping off straight away or just not coming on at all? listen for a cvlick as soon as u switch on. try another wall socket. check fuse
Apr 25, 2018 | Heating & Cooling
Problem(s?) Bosch WFO2864GB/01
check the 13a fuse in the plug if you have a heater fault it may well have taken the fuse out as well as the rdc the machine will also need checking to resolve the issue rcd's are very sensitive with most having a trip current of only 30Ma although the heater is first thing to check
Mar 03, 2014 | Bosch Washing Machines
Main fuse tripping when...
That could mean that there's a wiring fault (short-circuit). Unplug the unit from the wall socket and see if the breaker closes again.
If so: check the building wiring (get a certified electrician!)
If not: the heater wire is probably the cause. If it's a new unit, you should return it to the store for exchange. If you have no more warranty, have someone with electrotechnician skills replace the wire.
Dec 15, 2013 | Computers & Internet
I have an 03 error displayed on a Bosch WFK 2801 washing machine. Error only shows when machine is used with high water level function selected, otherwise it works. Why please?
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Nov 30, 2009 | Bosch WFK 2401
Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Sep 08, 2009 | Bosch WFK 2401
Wont power up or do nothing
Check wall socket then fuse in plug
Aug 11, 2009 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
