Question about Toro Garden
Change drive chain rear, no more aujust left?
No more aujestment left to change chain.
    Scholar:
  • 61 Answers
Can you take a link out?
Posted on Nov 26, 2013
  • bill ellis
    bill ellis Nov 27, 2013
    i think that will work
How to replace front sprocket
To replace the front sprocket follow the chain to the cover on the left side and remove it, loosen the chain tensioners on the rear axle, slide rear wheel all the way forward and remove chain. Then remove the bolt in the center of the front sprocket, change sprocket and reverse process for assembly. That is the process but if you are going to change the front sprocket you should change both sprockets and chain, as the chain stretches and will cause premature wear of the new sprockets. Complete sets can be found on Ebay for little money, maybe they are not the best but as long as you do not abuse them they will do until you get the money for a good set.
Feb 24, 2014 | 1994 Honda CBR 1000 F
Bad rear drive chain
on what ??? model # serial # brand, type of equipment... Only then can you get a helpful answer.
Nov 26, 2013 | Toro Garden
Rear drive left chain breaking on a regular basis. can,t find any reason for this . any ideas
there are two reasons for chain breakages . One is chain tension too tight or too loose and second is the sprocket teeth are badly worn and actually trying to get our of mesh. This will be amplified if the chain is too tight.
Oct 26, 2013 | Air Tools & Compressors
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
Putting new belt on wide glide do have to remove clutches and chain drive transmission?
yes. the entire primary drive must be taken off and the inner primary on all Big Twin bikes to change the final drive belt. The good thing on the Dyna is that you don't have to pull the rear swing arm like you do on the other models. Just remove the rear wheel and the left side shock.
Good Luck
Steve
Jan 30, 2011 | 2006 Harley Davidson FXDWGI Dyna Wide...
The chain keeps coming off.why?
Chains must not have too much slack in them. There should be about 1/2" (12mm) of vertical movement on the slack side.
It could be your have a worn out chain.. Look at the drive pinion. The teeth should have a flat top and both faces of the teeth should have the same profile. If the sprocket is very worn, the teeth become pointed and the chain does not sit correctly on the drive chain wheel on the rear wheel, (i.e. there is a gap between the chain and the inside edge of the driven sprocket.
If you change your sprockets, change the chain also (you must do this as the chain will also be very worn).
Mar 21, 2010 | 2002 Suzuki GZ 125 Marauder
CHANGE DRIVE BELT . HOW DO YOU ACCESS THAT INSIDE SPROCKET
You have to disassemble the entire primary system. Disconnect battery. Pull the outer primary cover, drain the oil first. Remove the engine sprocket nut (165 ft. lbs. torque) remove clutch assembley (left handed nut) and primary chain. Remove starter. Remove the inner primary.
Remove rear brake caliper. Remove rear wheel. Remove swingarm from frame.
This is a major job. It requires a torque wrench that will torque in the left handed direction and must have a range of 60 to 150 foot pounds.
Oct 06, 2009 | 2005 Harley Davidson FXSTB - FXSTBI Night...
I keep getting a flashing "auto aujustment in progress recom setting 1440 x 900- 60hz it just keeps flashing but wont adjust
Go to menu on the bottom of your monitor. Select "image control" once there click auto adjustment. That should change it. Let me know.:)
Jun 25, 2009 | HP w1907 LCD Monitor
2001 Ford Sport Trac - Front & Rear Timing Chains
The rear timing chain (or "cassette" as it's called in Ford lingo) is the chain that drives bank #1 (passenger side) cam. The front timing chain drives bank #2 (driver side) cam. There is a also a primary "jackshaft" chain that is driven by the crankshaft in order to enable both banks to be driven through a common shaft. The reason for this peculiar layout is because this engine is a "derivative" of the 4.0L OHV V6 engine it replaces. Ford simply installed a dummy shaft in place of where the camshaft used to reside on the original OHV engines. But above all else, the job you describe SHOULD NOT be carried out by anyone unfamiliar with this particular engine. There are NO timing marks on any of the drive sprockets, nor are they key to their corresponding shafts. To time this particular engine requires use of FIVE dedicated Ford/Rotunda tools that hold all relevant parts in proper position. Failing to carry this procedure out correctly, will result in the bending of ALL valves with 100% certainty!!! Therefore, it is best left to a Ford dealer technician to carry out. If you would like more information regarding diagrams, TSBs, and procedures with detailed illustrations, please e-mail me directly with your FULL Yahoo e-mail address so I can attach PDF files. Hope this helps.
May 18, 2008 | 2007 Ford Sport Trac Limited
Garden Logo
52 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
