Question about Crafts & Hobbies
How do you take cover off a lionel 1026 transformer to replace the electric chord
2 Suggested Answers
SOURCE: I have a lionel type KW Trainmaster Transformer
New wire and plugs are available at chuckstrains.com , they can also tell you how to get into it
Posted on May 10, 2013
How to remove the red handle and how to get to the fuses
You can't. These transformers aren't user serviceable. You can thank the Federal Government for that. If you can find the special tool to remove the case, you'll be able to open the transformer. For service, contact Lionel customer service or take the transformer to a Lionel Service Center.
Aug 14, 2015 | Lionel Cw 80 Transformer
How do you open lionel transformer cw-80?
On the base of the transformer you will find 4 tamper proof screws that you will need to remove to open the case. A triangular blade screwdriver will be need to do this. Once removed the tamper proof screws can be replaced with self tapping screws.
Silverhill Tools ASDTR1 Triangle Screwdriver
Jul 16, 2014 | Lionel Cw 80 Transformer
My transformer did not work
The internal fuse is probably blown. Contact Lionel at Lionel.com for instructions on how to get a replacement.
Jan 20, 2014 | Lionel Cw 80 Transformer
Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Dec 16, 2011 | Lionel Cw 80 Transformer
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
My lionel rw transformer won't run the train unless ithe speed control is turned 3/4 way up or better . Can this be fixed ?
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
Dec 25, 2010 | Lionel Cw 80 Transformer
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Nov 18, 2008 | Lionel Cw 80 Transformer
Crafts & Hobbies Logo
55 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
