Question about TPI Heating & Cooling
TPI H2508N Manual
Looking for a manual for a TPI Corp H2508N 240/208 volts 2000/1500 watts base board heater.
What is the current draw for ew0507k?
The manual shows 1500 Watts
1500 Watts divided by 120 Volts = 12.5 Amps
Kenwood EW7507EK Instructions For Use Manual
Aug 11, 2014 | Kenwood Heating & Cooling
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
I cannot get my TPI Corp baseboard heater to turn off. It kicks on even when it is not that cool in the room.
If the unit kicks on at too high a temperature, then it is probably the thermostat. If it will not turn off then it is probably the switch that is bad. Since you gave both indications, you could have two components bad. NOTE: Normally calling a technician to repair this item is more expensive than replacing it with a new one yourself.
Jun 18, 2011 | Electric TPI CORP TBS BASEBOARD HEATER...
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
Looking for the manual for laarslite teledyne
I thought I had that address for you. I must have lost it last time I cleaned up my computer.
Laars is now part of the Jandy Corp. I'm sure that is where I found it last I needed it. It is a good place to start
Jul 07, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
New heaters need to do a start up or testing for proper operation model f2f5103n TPI corp. Industrial type heater
When you are ready to test run the unit you should take an amperage draw reading on the elements.
The formula to see if the elements are drawing the correct amps is: (voltage x amps=watts) example: If a heating element is 1500 watts and your voltage is 120 volts, then your amps will be 12.5 amps. (120v x 12.5A=1500W)
The easiest way to check amp draw is with a clamp on amp meter.
Nov 24, 2009 | Fahrenheat Ceiling-Mount Industrial Heater...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Loose power when turing it on
sounds like it is wired incorrectly at the baseboard heater. BUT if it worked correctly before this, then you may have a bad thermastat. Wiring in two baseboards into one thermastat is a bit tricky, each time I do it I have to think it thru before hand to get it right. IF it has never worked right, again you probably have it wired in wrong at the baseboard.
Dec 14, 2008 | Electric TPI CORP TBS BASEBOARD HEATER...
LOOKING FOR INSTALL / MAINTENANCE MANUAL
anyone know i am installing new base boards 1500 or 2000 240 volt how many wan i put on one circiut
Apr 28, 2008 | Heating & Cooling
Heating & Cooling Logo
Top TPI Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a TPI Heating and Cooling Expert? Answer questions, earn points and help others
