Question about Camping, Backpacking & Hiking
Schylling head lamp not working
Added the 2 AA batteries but not lighting
Brake lights 1999 jeep. When head lights turn on, the third brake light works the other two go dead. during the day they(brakes?) work, but brakes are dim, with HL on, any help??
If the brake lights are to american system ?? then maybe a new switch .If europeon system then ??? i would start looking at the wiring loom on the tailgate door to body in the rubber boot .
Dec 17, 2016 | Jeep Cars & Trucks
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
I have a 1999 1500 pickup turn signals wont work with head lights on will work if the ad lights are off any answers
I would be looking for poor grounds in the tail light and head lamp area. It is the black wire
Jun 23, 2014 | 1999 Chevrolet S-10 Pickup
Head lights dims out
old post day, Geo underdogs.
is engine running, seem yes, pretend yes...
high and low beams dim (means weak not low or high beams)
dim bulbs. all elements, left and right sides?
well first is battery voltage
use a $10 walfart DMM meter., (set to volts)
13.3. to 15vdc is the voltage running, on a hot engine rpm is 700+
RPM not 400. so, if all that is good, the ALTERNATOR IS doing its job, yes, the regulator is inside the alternators and changes voltage , by SENSING batteries needs, and sensing driver added loads, (accessories)
so if battery voltage is good, the what is it,
well that is easy head lamp failure
got DRL do you have the infamous, and pesky DRL daylight running lamps as the law requirements in CANADA,
next time say DRL or canada, ok?
if all lamps are dim on the HL,
the the ground to them are bad.
there are 4 bulbs , 2 high 2 low, all for dim is bad ground there.
the Headlamp relay sends 12vdc to all 4bulbs, and most read 12v or more.
the lamps are grounded by the HL combo switch on THIS car
the ground must be good to this switch 0v, HL onl.
or the ground is bad. a white/black wire called G200
if 12vdc is weak (low) to HL then the relay or wire to it are bad.
if the ground is not 0v, (no more than 0.5vdc) then the ground is bad. if the ground is good, then the HL switch is bad and if bad gets hot and smell... (melting plastic in side)
there is the full answer, sans DRL> (a longer story that)
Feb 24, 2014 | 1991 Geo Prizm
Dashboard light go in and out
incredible, is car running or not?
EG: key on only.
EG key on end running.
Gee! pretend the helper is blind, we are..
there are 2 kinds CLUSTER of lights
1: WARNING LAMPS. (all com on keyon as test)
2: AND PARKING LAMPS. that can be dimmed....
3: and gauges they too use CLuster power so....
which ones.?????????? name all lamps and bad.
does engine run??????????
do head lamps work and not be dim?
we need all lamps that work and not.
both.
your car electronic tech, would see all this in 5 minutes work , I say let them'! not me im retired.
A primary test, for power.... (works key off too)
if head lights are dim or fail?, or act odd
that is a dead/week battery (or just discharged)
or just ignoring the terminal lug cleaning service steps. (that is a top failure, "A1" failure.
also modern cars with lots of computers!
they all go very crazy, with low battery voltage.
use a thing called a voltmeter to check system volteges. battery is 12.6vdc rested.
even the $10 walfart, meter works. here. prefect.
and running, 13.3 to 15vdc good. is it?
Jan 28, 2014 | 2005 Suzuki Forenza
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
Cannot get the light to work and does it have an on switch
I had a similar one. There are screws in the feet. Open them to see the 2 AA batteries. If it still don't work the light bulb is probably dead.
In any case its much better to use an external light source. I used a 60 watt bulb in an adjustable lamp.
Mar 14, 2013 | Vivitar Deluxe Kit Micro View Microscope...
'86 Mustang Head Light Switch Pin Out Connectors?
I can give you 94 mustang. Don't have 86 but maybe similar
7fc8945.gif Pin Number Circuit Circuit Function B1 38 (BK/O) Power Supply to Battery B2 195 (T/W) Tail Lamp Switch Feed I 19 (LB/R) Instrument Panel Lamp Feed IGN — Not Used R 14 (BR) Headlamp Switch to Tail Lamp and Side Marker Lamps H 15 (R/Y) Headlamp Dimmer Switch Feed DN — Not Used D1 54 (LG/Y) Interior Lamp Switch Feed D2 706 (GY) Battery Saver Door Switch Feed
Apr 30, 2009 | 1986 Ford Mustang
Camping, Backpacking & Hiking Logo
64 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
