Question about HP PSC 2175 All-In-One InkJet Printer
Not printing it is saying right cartridge incorrect after refilling cartridges
It's a great idea! In fact i tried to do that only one thousand times...and the messagge is always the same!!!
Posted on Dec 13, 2007
SOURCE:
X3350 printer says incorrect right cartridge
My be ink cartridges has not refilled in proper way.Are you sure your cartridge are compatible with printer?
You can follow the given steps..
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the power button button is not lit, press power button.
  5. Reinsert the print cartridge.
If the error:
  • Does not reappear, the problem has been corrected.
  • Reappears, replace the print cartridge with a new one.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Lexmark X Office Equipment & Supplies
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Refilled black cartridge 36 on my 5650 won't work
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
Feb 02, 2010 | Lexmark X2500 All-In-One Printer
Color ink cartridge
Hello sir; Please do not use refill cartridge ! , one cartridge not right all cartridge don't work. change back the refill one.
Aug 02, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark X4530 Incorrect Cartridges.
By any chance did you get these cartridges refilled? If so then you may be out of luck as I read that Lexmark chip their cartridges/printers to reject refilled cartridges. I have the same problem at the moment just with the right (colur) cartridge. The cartridge is an original refillable Lexmark (i.e. grey box) I got the cartridge refilled twice and it worked fine, but the third time no joy. Research indicate that Lexmark program their printers to reject cartridges refilled 3 times!!
Jul 07, 2009 | Lexmark X4530 InkJet Printer
Refilled cartridge , printer says right cartridge incorrect
Lexmark builds intelligence into their cartridges and printers to prevent the use of refilled cartridges.
Lexmark has never approved the use of anyone else's ink for their printers primarily because there is no way to prove the quality of the ink.
Please purchase a Lexmark cartridge.
May 09, 2009 | Lexmark X7350 All-In-One Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Cartridge errors..cartridge incorrect
sounds like they're the type of cartridges that cannot be refilled, due to the computer chip on them.
Dec 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP PSC 2175 All-In-One InkJet Printer Logo
51 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
