Question about Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer
Peterbilt retrieve flash c odes - Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer
Im trying to find out where the resistor to the control blower fan speed is located in a 2016 Peterbilt truck so i can replace it, the part # p93caa3100-01s
Have you tried the user manual, have you contacted where you bought the truck from. What about googling your iPad or iPhone. For trouble shooting advice
Oct 29, 2016 | Cars & Trucks
95 peterbilt 3306 oil light stays on
I don't have any experience with peterbilt trucks, but I have seen this problem several times on several different vehicles with both lights and gauges. Each time but once, it was the oil sending unit. The one time it wasn't the oil sending unit it was the oil pump had went out. I'm not sure this will help and I don't know how to check the oil sending unit. I just replaced the unit and that fixed the unit all but that one time. You can pull the unit and put an oil pressure gauge on it to check the oil pressure but I didn't have one so I just replaced it. I don't know if this helps but you're welcome to the info.
Feb 16, 2014 | Air Conditioning Evaporator 1995 Peterbilt...
1994 Peterbilt I need a complete Heater Hose Diagram
has to be some diagrams on internet somewhere. Did you try Peterbilts web site?
Nov 19, 2013 | 1994 - 1996 Peterbilt 200-33 Engine...
How do i pull active codes without a computer off of a Peterbilt
Newer equipment you cannot use switches and get flash codes.
The systems are simply to complex to use simple flash codes
There can be 4 different conditions of the same code (meaning there could be a Voltage High of Voltage low) there are also different severity levels for codes.
The only way to read new engines is to have the built in display with the Multiplexed system that shares Data with the engine ECM
Aug 15, 2009 | Upper Deck Iowa State Ncaa Peterbilt...
Unlock code for car cd player
If you can not find you ode in your trucks Owners Information under CD, Contact your Mitsubishi dealer with VIN# on the lower edge of your windscreen nd they should be able to retrieve the code from the VIN when you are given the code enter it with the station preset buttons. Best of Luck
Jul 15, 2009 | Car Audio & Video
Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer Logo
44 people viewed this question
Top Upper Deck Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Upper Deck Toy Expert? Answer questions, earn points and help others
