Question about Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer
Retrieve flash coded on peterbilt - Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer
Poition of o b d socket, 1989 lebaron convertable cheers baz
Your '89 has no OBD plug in. To retrieve codes, turn key on, off, on, off, on, off, and then leave on. (Cycle key 3 times on-off, then leave in ON, do not start engine.) Codes will begin to flash on the check engine light (cel). All codes are only 2 digits. Probably see a code 12-one long flash and two short flashes-code 12 is normal, disregard it. If you have to, keep repeating the codes until you get them all. Post them here, or google the codes for help.
here is a link: https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-truckshttps://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Nov 30, 2016 | Cars & Trucks
1994 Peterbilt I need a complete Heater Hose Diagram
has to be some diagrams on internet somewhere. Did you try Peterbilts web site?
Nov 19, 2013 | 1994 - 1996 Peterbilt 200-33 Engine...
Flashing overdrive light
Flashing overdrive light mean there is a malfunction in the trans
mission. Retrieval of codes become necessary. Retrieve the codes, post the code number here and then find the solution.
Aug 04, 2012 | 1992 Toyota Celica
Need to know what the wire color corresponds to
red doesn't necasarraly mean anything check with peterbilt service or parts dept
Mar 12, 2010 | Car Audio & Video
How do i pull active codes without a computer off of a Peterbilt
Newer equipment you cannot use switches and get flash codes.
The systems are simply to complex to use simple flash codes
There can be 4 different conditions of the same code (meaning there could be a Voltage High of Voltage low) there are also different severity levels for codes.
The only way to read new engines is to have the built in display with the Multiplexed system that shares Data with the engine ECM
Aug 15, 2009 | Upper Deck Iowa State Ncaa Peterbilt...
Engine code retrieval for a 1999 dodge avenger
3 times ..turn the key > off on off on off on .> then count the flashes of the light , flash flash pause flash flash , = 22 , pause , i think when you see 5 flashes pause 5 flashes , that means end of list . there might be multiple codes , have a note pad , you have to do it twice to be sure of the code(s) .
Jan 22, 2009 | 1999 Dodge Avenger
How do i get the error codes from a 95 astro van without a diagnostic tool
place a jumper wire between terminals A and B of the diagnostic connector , located just under the steering column,pointing staight out. Turn the key on and after the initial 12 code ( flash ,pause, flash,flash), you can count the flashes to retrieve the error codes. ex. *** ** equals 32. each code will show 3 times . When 12 returns , you have retrieved all the stored codes. Good Luck.
Jul 23, 2008 | Chevrolet Astro Cars & Trucks
Upper Deck Iowa State Ncaa Peterbilt Tractor Trailer Logo
35 people viewed this question
Top Upper Deck Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Upper Deck Toy Expert? Answer questions, earn points and help others
