Question about Raymarine KVH TracVision R4sl 12 Stationary Satellite TV System
Cannot communicate with circuit board
KVH suggested to send it to them. RF board does communicate, main board does not
Samsung fridge RF 266 ABPN what does error code pc er mean
it means there is communication issue. most common problem is main control board on back of refrigerator..
hope this helps.
Jan 25, 2017 | Samsung Refrigerators
RF Remote Problem
Could anything other electronics be interfering with the signal?
Aug 18, 2008 | KVH Additional M2 Or M3 St Receiver Kit...
Can not locate satellite continues to search
There are few possible reasons.
Antenna can't "see" satellite.
Wrong data programmed.
Wrong skew angle.
Damaged RF board.
If you make log-file it will be much easy to understand your problem.
Jun 26, 2013 | KVH 01 0277 01sl Tracvision A7 Mobile...
Kvh tracvision r4
In those KVH dome antennas there is a belt attached to the motor that makes the antenna rotate on the inside. When this is not moving then it really can only be a couple of things. Either the belt is broken or worn down which is not letting it rotate the antenna, or the motor that moves the gears in which the belt is attached has gone out. In both these cases either the belt must be replaced or the motor must be replaced. if you need anything else or have any other questions feel free to contact us at 877.299.9931, or you can take a look at our website at www.NorthernAxcess.com. We have a full satellite communications service and repair centre in which we handle KVH repairs and other satellite internet terminal repairs and parts. We also do satellite phone repair and parts, and BGAN satellite modem repair and parts. Satellite phones such as iridium extreme 9575 satellite phone repair and parts, iridium 9555 satellite phone repair, iridium 9505A satellite phone repair and parts, and the inmarsat isatphone pro satellite phone repair is some of our specialties. We have many years of experience and friendly technicians. We have a dedicated site for repairs at www.NorthernAxcess.com/satellite-phone-repairs-and-bgan-repairs . We are a Premiere satellite communications service. We also do satellite phone sales, rentals, airtime, and installations. Call us...
Sincerely,
NorthernAxcess Satellite Communications Support Team
May 31, 2013 | Televison & Video
My rci ranger wont transmit but it receives great what is the problem
it could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a few.my suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Apr 04, 2013 | Ranger Communications RCI-6900F-25 CB...
My KVH M3 will not lock on to a satellite, when I run anttena diagnostics everthing is OK except RF Low: 500 and I do not know what this means
RF low means low signal from dish. Maybe blocked satellite, maybe poorly crimped coax, maybe bad sat receiver. Most likely, bad coax crimp!
Dec 23, 2009 | KVH Tracvision M3 Satellite Tv System
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
I use to hear my tracvision a5 spinning and finding the satellite
There are two fuses on the main board in the dome, check them
Mar 30, 2009 | KVH TracVision A5 Car Video Player
GPS signal is weak or no signal
Bozena/Anton,
Thanks for using FIXYA!
Careful when opening the case because you'll have to unplug the cable from the main board prior to opening the case completely.
The RF cable could be loose inside. Carefully open the unit as to not potentially cause any further damage. The RF cable will be gray or black, it will be the only cable connected from the main (big) board to the RF (attached to the rear housing.. I believe) board. The connectors on either side of the cable have came loose. A "pad" being lifted results in a repair process that's beyond me, this meaning you can see white as opposed to silver. It may help continuity to re-flow the solder, if everything looks fine (heating up the existing solder and adding fresh solder).
Unplug the cable on both ends and plug back in to make sure the connectors on the circuit board aren't coming loose. If soldering is out of your league then I suggest finding someone that can. Let me know what happens, and careful when opening the case because you'll have to unplug the cable from the main board prior to opening the case completely.
Oct 26, 2008 | Magellan RoadMate 700 GPS Receiver
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Raymarine KVH TracVision R4sl 12 Stationary Satellite TV System Logo
32 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
