Unidentified network - Computers & Internet
  • Ap12
    Ap12 Dec 06, 2013
    Hi mark Santaguida, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
LAN connection shows "Unidentified network" when connecting through Aztech Homeplug
Check the network Cable type which you used to connect the Homeplug to Router, Check with both the type of cables (Straight and Cross) and Let me know if it works
Mar 06, 2014 | Computers & Internet
On my WIndows 7 computer it shows that my wireless is connected, but it also says, "Unidentified Network, no internet access" and I can't get on
Click on the network icon (five vertical bars, next to the speaker icon, bottom right of screen). When network window opens, click on name of network. If a blank box opens with a message asking for the network key, enter the security code that you entered after the WEP setting on initial installation.
If this doesn't work then I suggest that you re set the modem to factory default and go through the initial set up again, choosing a new name for the network.
Nov 22, 2012 | Computers & Internet
Linksys router unidentified network....receiving full signals but showing unidentified network ...i hv checked SSID and key both are correctly entered....
Try resetting the router and then configure it again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 15, 2012 | Linksys WRT160N Wireless Router
Belkin f5d8235 unidentified network
Does it ask you for the wireless security password while connecting?
I think you can try creating a new wireless network on the router and see if that works.
What is the operating system on your computer?
How many wireless computers do you have?
Read information about wireless network connection on windows computer
Jun 14, 2012 | Belkin (F5D8235-4) Wireless Router
The netgear program says that I am connected but my comp says its an "unidentified network"
if it says Unidentified N/w, Means u have Typed wrong Password
Or else Jus try to Restart the Computer and once again Connect to Wireless
all the Best................
Oct 05, 2010 | NetGear WG111 802.11g/b Wireless Adapter
Dell inspiron. "unidentified network" problem
Try disabling firewall software that must be preventing access to network. disable and reenable the lan card might also help
Feb 01, 2010 | Dell Inspiron 1501 Notebook
Multiple networks appear after reboot on lan desktop. OS is Vista Home Premium 32 bit with DIR615 router. I have to disable and enable lan network in order to get rid of the Unidentified network and enable...
the reason could be the networks scanned by your wireless card when it starts up. What you could do is go to select your preferred netwrok and bring it to the top of the list . ( In the wireless configuration utiity ).
Thanks Ranjit
Jan 05, 2010 | D-Link DIR-615 Wireless Router
download latest drivers from downloadfinder.intel.com
Nov 29, 2008 | Intel PRO/Wireless 3945ABG Network...
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Your office network is probably hidden you will need to change the settings on the router. Talk to your Net Admin about it.
May 21, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
