Question about Canon FAXPHONE L80 Laser
To receive a fax, the phone rings twice then switches to a busy signal
3 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: fax line stays busy continously...
Are there any other phones that use that line? If you have a phone attached to the fax machine, is the reciever in the holster all the way?
Posted on Jul 06, 2008
goalie39
  • 469 Answers
SOURCE: Fax line is busy
check the hand set is correctly seated on its cradle.
Check the Hook button on the front of the machine.
Disconnect the fax machine from both the phone and power lines for several minutes, reconnect and try again.
UserGuide
.pdf">http://static.compusa.com/pdf/canon-FAXPHONE_L80-UserGuide.pdf
I have included a copy of the users manual in case you are missing yours.
Hope this helps
Ed
Posted on May 20, 2009
I can not receive faxes,
TRY CALLING YOUR FAX FROM YOUR PHONE.DOES FAX RING,DOES IT SAY RECEIVING IS YOUR PHONE GETTING BUSY SIGNAL. BE SURE PHONELINE IS PLUGGED INTO LINE SLOT ON FAX NOT IN TEL. SLOT IF YOUR FAX GIVES NO INDICATION IT IS BEING CALLED
PLUG A PHONE INTO WALL JACK IF PHONE WORKS YOU COULD HAVE BAED PHONECORD OR MODEM PWB IN FAX IS BAD IF PHONE PLUGGED INTO WALL DOES NOT WORK CALL PHONE CO.
Apr 09, 2010 | Office Equipment & Supplies
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
Can send fax but cannot receive fax. cannot copy
With your cell-phone, dial the telephone-number for the FAX interface.
Does your cell-phone "ring", or do you get an "intercept" ("this number is not in service") or do you get a "busy" signal?
Does the FAX "answer" after one ring? two rings? three rings? does it NOT answer?
Dec 10, 2009 | Epson Office Equipment & Supplies
When I fax it says phone off hook. I get a message stating no answer.
Try dialing the FAX-number with your cell-phone.
Do you hear the "ring", or does the telephone-company give you a "busy" signal ?
Some FAX machines are "busy" -- receiving many FAXES from multiple customers -- reprogram your FAX machine to "retry" a few times.
Or, when a receiving FAX runs out of paper, it sometimes refuses to accept "new" faxes.
Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Companies trying to fax to our office tell us that our fax number is "BUSY" but the faxes we receive "failed" and nothing is printed.
Take a cell-phone, and dial the telephone-number that you are giving to your customers. Does it ring? Does the FAX "pick-up" the call?
Or, do you get a "busy" signal?
Nov 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
1. Press [Menu].
9. Press [Stop].
Aug 11, 2008 | Office Equipment & Supplies
HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Aug 10, 2008 | HP 640 Inkjet Fax Machine
Can't receive a fax
Make sure the phone cord from the wall is plugged into the port in the back of the machine labeled "line" and NOT "phone"
Aug 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Receiving Faxes
Can you receive a voice call on the same line? Call the machine with your cell phone and see if it rings and you can hear your voice on the fax receiver. Use your manual to check the settings.
Feb 23, 2007 | Brother IntelliFAX 4100 Laser Fax
Canon FAXPHONE L80 Laser Logo
old marine
old marine
