Question about Archos ARNOVA 10 Android Tablet
It goes off evertime I unplug the charger
I plug it up to charge the light turns green after charging and when I unplug it it goes off.
My Irulu 9" tablet I got new. I had it few months is now acting up bad.It only comes on when I plug it up on charger
change the battery
it probably is defective or has developed a memory level for charging when not real low
Oct 01, 2016 | Tablets & eReaders
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Why doesn't it turn on?
either your charger isn't charging or your battery is bad
Dec 13, 2015 | Tablets & eReaders
MY DREAM TAB I LOST THE INSTRCTION ON HOW TO CHARGE BATTERY
Plug the tip of the USB charging cable into the power charger port and plug the other end into the USB Power Adapter. Plug the USB Power Adapter into an electrical outlet. You will know that it is completely charged when the orange light on the charge indicator turns green.
Jul 23, 2015 | Tablets & eReaders
Will not charge. Plug it in green charge light goes on, screen flashes battery low, screen shuts off green light goes out
Try resetting your Kindle. Turn off first then hold power button down for about fifteen seconds and it does a reset. This should correct the problem. Make sure you have a charger made for Kindle and not a generic one.
Jun 12, 2015 | Amazon Kindle Fire HD
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
Pioneer r1 tablet won't hold charge
My Pioneer R1 Tablet ALSO will not Charge only works when plugged in if i unplug it goes off! Charging stays at 0%.
Mar 19, 2014 | Tablets & eReaders
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Archos ARNOVA 10 Android Tablet Logo
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
