Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Hoover Bagless WindTunnel vacuum cleaner.
Has suction but does not pick things up when pushing the vacuum cleaner. Brushes move and the hose suction will clean and pick things up.
  • 98 Answers
Very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Posted on May 08, 2009
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
How do i stop the dust/dirt from coming out of the hose tube when i remove the hose to use attachments?
It sounds like your hose is stopped up. This is a common problem with bagless machines. It's a good idea to buy a bag type vacuum cleaner when this one quits. Most of these chinese made , bagless cleaners only last one year and don't perform very well either. They stop up easily because of poor suction and poor design.
May 08, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
My Hoover Dual V Windtunnel has suction but the brushes are not turning. How can I troubleshoot?
Take the lower plate off of the unit and check the belt for breakage. also, if it isn't broken, are there any obstructions between the belt and housing?
Jan 29, 2010 | Hoover U6630-900 WindTunnel Bagless...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
My hoover upright has no suction, the brushes move but it doesn't pick anything up at all
Hi there...
I had the same problem. Checked for obstructions, cleaned the filters, etc.
 I took out the rubber belt and noticed that it was much more stretched than the newer black belt.   I replaced it, and it made a 100 percent improvement on the suction.
Your vaccuum should have come with a postcard that allows you to mail in belts for new ones. You'll get two new ones in the mail, and they are free for life.  Just keep mailing in the old broken or stretched out ones.
Hope that works!
Mar 17, 2009 | Hoover U5753-900 WindTunnel Bagless...
Brushes spin but the dirt does not go into suction hose
Most likely you have a clog. Starting at the brush head check every part of the lines for debris. More than likely YOUR clog is in the hose... easy enough to take a broom handle and gently push it through the hose (while the hose is NOT attached to the vacuum) Once you find the clog, you may have to use a little more pressure, but do so carefully, as you don't want to damage the hose itself.
Jan 19, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
685 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
