Question about Tappan TEF242 Electric Kitchen Range
Timer clock will not stop buzzing! - tappan 31 series slef-cleaning oven.
5 Suggested Answers
  • 26 Answers
SOURCE: clock on Model F120 stove Serial 53031577
just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
Posted on Jan 09, 2008
SOURCE: Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Posted on Oct 03, 2008
SOURCE: Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: tappan series 110 gas range
Takes about 15 minutes to fix. You will need a philips head screwdriver, pair of scissors and a butter knife. What you're going to do is cut the wire to the beeper. Your clock will still function.
Start by removing the glass faceplate that encloses your clock. By removing the 2 screws on either side of the metal housing, you can remove the faceplate (you'll have to remove the clock's pushbuttons, but that isn't hard, either. I used some spring-loaded pliers to get a good purchase, then pulled straight back. Oh yeah. You need pliers, too. Don't worry, you won't break the buttons; they'll snap out and push back in, later). Use the butter-knife to carefully work the glass out of the metal frame. The actual clock is secured by a couple more screws, which are easily removed, once you've removed the abovementioned faceplate.
[The clock, btw, is made by Fridgidaire (part # AP2125434 ), in case you want to replace it. Costs more than $130(!)]
If you haven't already unplugged the stove, now is a good time. Do not touch the two metal connectors of the two most prominent wires on the back of the clock, when the unit is plugged in! Yes, it's the voice of experience, talking...
You will notice, when you're looking at the back of the clock unit, a small metal disc, enclosed in plastic. If you plug in the stove, and listen, you should hear the beeping coming from this area. There is a medium-sized hole in the middle of the plastic housing, allowing access to the metal disc. There are two very small wires, red and black, leading into the housing and attached to the disc in two places. One wire is attached to essentially the center part of the disc. The other wire (in my case, the black wire) is attached rather toward the outer edge of the metal disc. The outer edge is even a slightly different color, so you can identify the two parts. In my case, the sound was emitting from the outer edge, as opposed to the center portion of the disc. If you press a Q-tip against the center portion of the disc (thru the hole in the plastic housing), and the beeping continues, unchanged, the sound is probably coming from the outer edge. You can check by bending the Q-tip, and working the tip over to the edge of the metal disc--by applying pressure, you should hear the sound change, slightly.
Unplug the unit, and cut the wire that corresponds to the part of the disc the sound is coming from--that should solve the problem!
Posted on Nov 16, 2009
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
TIMER IS BUZZING NON STOP.
how old is the oven? does it have a analog clock? If it does then turn the stop time clock and the buzzing should stop.
Oct 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Feb 04, 2008 | Kitchen Ranges
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Tappan TEF242 Electric Kitchen Range Logo
422 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
