Question about Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Black
HOW DO YOU SECURE MOTOR TO RIDER
Motor has screw holes, but where do they attach to body? Wheels slide back and forth.
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
Sep 02, 2012 | 1997 Dodge Grand Caravan
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at. stevepiper@usa.com
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
Where is the ground wire located for a 1989 chev.s-10 windsheld wiper motor?
General comment: Most automotive wiring uses the body for the ground wire. Where is the ground? ... In the bolt or screw that fastens the motor to the car body. If the motor is mounted on rubber, as in isolated from the body, ... there should be a ground ... make one ... it can be attached from a good solid body connection to any part of the metal body of the motor. Get a wire and a screw, drill a hole in the body, wrap the sire around it securely ... fasten it to any part of the WSW motor.
Nov 12, 2010 | Chevrolet S 10 Cars & Trucks
How to replace rear blower motor motor in 2006 chrysler town and country van
from autozone.com:
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
Fig. Removing the trim panel to access the rear blower motor
i. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
j. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
k. Pull first rear seat belt through the access hole.
l. Remove the quarter trim panel from the vehicle.
3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
4. Twist the blower motor out of scroll housing.
5. Disconnect the blower motor wiring connector.
6. Remove the blower motor from vehicle.
Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
Nov 04, 2010 | Chrysler Town and Country Cars & Trucks
I have a two wheel jugs machine used for junior little league. The wheels will not get up to speed...can you help me?
I just fixed one with the same problem.
10 to 1 odd the brushes are stuck from sitting.
unplug unit.
take off the cover of the motor. 2 -7/16 nuts
there are 4 post one with black wire , white wire , ground and no wire.
you need to take off the two nuts on the one with ground and the one with no wire.
you can then remove the cover which will have the brushes inside.
once removed push the brushes in and out of the sleeve to loosen. spray with some liquid wrench or wd-40 and work back and forth. I took some steel wool and cleaned the copper where the brushes contact.
when you put it back together don't forget the scussion ring. it looks like a couple of potato chips put together. line up the slot on the casing with the nub on the perimeter of the brush housing,
slide it in while lining up the long screws with the holes in the housing. you will need to depress the brushes with a screw driver through the front hole , then slide it in . it will not go in the last 1/8th because of the scussion washer. tighten the nuts on the long screws and the gap will close. if you have the wheel off you can use a phillips screwdriver to hold the oth side , if not just hold the screw on the shaft with channel locks in the middle so you will be able to get the second nut started.
repeat on the other motor and you should be good to go
Joe
Feb 17, 2010 | Jugs Small Ball Pitching Machine
Brakes seize up and stay on after driving for a distance, especially in hot weather. They release when cooled down. Is this the master cylinder or calipers? Car is in good shape at 100 K. Garage kept all...
Jack car up, spin wheel, then apply brakes, and release and try spinning wheel again. If it doesn't spin just as easy, try cracking bleeder screw open, then try spinning wheel. If it spins easy after you crack bleeder screw, tighten bleeder back up & try same again. If same result, wheel spins when bleeder opened, then I'd replace the 2 front flex hoses that attach to calipers. If caliper doesn't release then you need to pull calipers and check if partially seized, or maybe slide pins that caliper moves on (that attach caliper to spindle) need cleaning and lube applied to allow calipers to move back & forth.
Aug 11, 2009 | 1985 Plymouth Reliant
Electic trimmer
You're going to take off like 20 screws including the ones that hold the handle and the hood at the base of the blade. You open it like a clamshell. There is a black plastic cover at the very bottom that covers the gear wheels (one tiny wheel that comes from the motor and a large wheel that actually moves both blades back and forth). The black plastic cover is no attached with screws. You just remove it so you can get to the gears. Now you oil and manipulate the large gear wheel until it comes loose and you can see the blades move back and forth. Put the whole thing back together and you are ready to go!
Jun 12, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Steering wheel installation
Does it move at all??? If so then the star bolt that goes in the center hole is the brake so to speak.
the lever that turns back and forth on the column has 2 small screws that attach to the lever.
tighten the center bolt until the wheel is secure, then set the tightening lever to the tight position and put the 2 screws in place. they will fit in between the star or teeth on the bolt and attach to the tightening lever.
Oct 04, 2008 | 1980 Chevrolet Corvette
Drill Presses Installation
Here are a few instructions to follow while installing a Drill Press: Fix the column support to the base using the three screws provided. Slide the table clamp onto the column and align the table with the base and secure it in position using the table clamp lock. Place the head assembly onto the column and slide it down the column as far as possible. Align the head with the table and base and tighten the head locking grub screws with the hex key. Fit the depth scale. Attach the feed wheel. Secure the feed wheel in place with the cap screw using the hex key. Fit the chuck safety shield over the collar of the spindle nose and tighten the clamp screw. Carefully clean out the tapered hole in the chuck and the spindle taper using a clean cloth. Hinge up the shield. Push the chuck onto the spindle and lightly tap the chuck with a piece of wood to ensure proper fitting.
Aug 27, 2008 | Makita TW0350 1/2" Drive Impact Wrench
Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Black Logo
43 people viewed this question
Top Lil' Rider Cycling Experts
ray gallant
Donald Ayers-Marsh
Are you a Lil' Rider Cycling Expert? Answer questions, earn points and help others
