Question about Kyocera Office Equipment & Supplies
Error call servicE C6000 KYOSERA 180 - Kyocera Office Equipment & Supplies
  • Kyocera Expert
  • 337 Answers
Fuser error. replace fuser.
Posted on Nov 30, 2013
5 Suggested Answers
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
  • 126 Answers
SOURCE: error C6000
This is a fuser problem. Try this to reset:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Posted on Jan 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: c6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
press enter
press enter
select execute
press enter
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 09, 2009
  • 990 Answers
SOURCE: KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Posted on Aug 23, 2009
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
Oct 28, 2015 | Office Equipment & Supplies
How t reset fuser error c6000 for taskalfa 180
Fuser reset: Press 'system menu/counter' key, select 'service setting', then while pressing 'start' and '#', press 'enter'. Select 'Maintenance mode', then press 'enter'. Enter '163' using the up/down keys, then press 'enter'. Turn machine off to exit Maintenance mode. C6000 indicates fuser did not come up to temp in the allotted time; you 'may' have a bad heater lamp if code reappears. Good luck.........
Thanks,
Sep 05, 2014 | Office Equipment & Supplies
Problem in printing, when you run TCT me c6000
c6000 is a fuser error code try replacing the fuser
Apr 12, 2014 | Kyocera TASKalfa 180 Copier
C6000 error
6000 error . Broken fuser heater lamp wire The fuser temperature does not rise after the fuser heater lamp has been turned on You need to reset it in engineers service mode setting 163 ,if problem still persists after resetting a new Fuser unit will be required
Nov 12, 2013 | Kyocera TASKalfa 180 Copier
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
Feb 17, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
I got the 400ci color kyosera copier. installed the cartridges, waste basket, when i turn on the copier it gave a "c3100" message. please advise.
c3100 is an error associated with the scanner carriage. open your document feeder and check if the carriage cables are OK.
Jun 13, 2011 | Kyocera TASKalfa 180 Copier
144 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
