Question about Acer Aspire 5002WLMi Notebook
Display I have an Acer Aspire 5002wlmi Pc Notebook i have aproblem with the display, the backlight is on but the picture is blank with backround colour relating to the startup screens and you can see fine lines like a crashed display, if you move the mouse you can see some sort of movement i can only discribe it as a very distorted picture like looking through very thick frosted glass, you cant see the outline of anythingand there is only one colour. restarting doesnt fix the problem and even the bios screen on start up is affected, if i connect an external monitor the picture is fine on that. if i restart a few times suddenly the display is back to normal it is intermittent but becoming more frequent could it be a bios issue? or is it hardware? please help.
  • Rolens Oct 11, 2007
    Thanks for your response but its not that the display is dim, the back light is fine. its the actual displaying of the image that suddenly goes wrong i had the problem again today, from power on the display was affected then suddenly the image appeared back to normal. im leaning towards bios or software issue. any other suggestions would be appreciated.
  • Anonymous Nov 27, 2007
    screen
    President:
  • 317 Answers
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Posted on Oct 10, 2007
Screen is blank lights come on
Hook a external monitor to the video output usually on the back. If picture okay! the inverter board below the screen is defective, or the backlight behind the display has failed. But if both have the same symptom it is the Video Graphics Card that is the issue, normally built into the motherboard.
Apr 05, 2012 | Acer Aspire 5102WLMi Notebook
Acer aspire one half screen blank
you have 1 of 2 problems
1 - faulty backlight inverter or
2 - dead backlight tube [there are 2]
either way it must be replaced
need to open up the display portion of your laptop
Dec 04, 2010 | Acer Aspire One PC Notebook
Acer aspire one no boot menu screen blank power light on no other lights showing except a brief flutter on when using power button when pulling power lead out display show flicker of light
sounds like your lcd inverter may have went out,,,thats a good chance ,,its what powers ur lcd backlight,,check acer website for support,,
Nov 03, 2010 | Acer Aspire One PC Notebook
No display on the monitor but thre is power
Hello, Dennis.
The most common reasons for blank display when there is power on the laptop is the inverter or backlight. The inverter is easier and cheaper to replace than the backlight. If you can see very faint images on your screen, usually the inverter is the problem.
Hope this helps.
Nov 18, 2009 | Acer Aspire One PC Notebook
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
Display problem
recover ur hard disk drive
Oct 14, 2008 | Acer Aspire 5002WLMi Notebook
Monitor Problem
This is probably the result of using the wrong display driver. It may even be set for an external monitor. If it was used with an enternal monitor, connect it up to the same one (or something similar) and use the display settings to get the computer to use the LCD as the primary.
Jul 09, 2008 | Acer Aspire 5002WLMi Notebook
Screen went out on my Acer Aspire 5102WLMi
as per your information your display adapter(if onboard) or video card is defective.replace it
Apr 02, 2008 | Acer Aspire 5002WLMi Notebook
Display resloution
if it is your desktop resalution go to display properties
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 10, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5002WLMi Notebook Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
