Question about Ovens
Steam not working
Temperature not going up
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
How I can fix the Message
Depending on the make of the oven the error code E011 can indicate a faulty temperature sensor or bad control panel when steam escapes from the oven and into the panel. In either case this issue usually requires a repair technician to fix the problem.
Dec 23, 2014 | Ovens
RATIONAL CPC GAS
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Mar 21, 2014 | Combi Ovens
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Nov 14, 2013 | GE JTP70 Electric Single Oven
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
Nov 28, 2011 | Combi Steamer electric built in steam...
A crew member reported that the oven wasn't working last night...he pulled the plug. When I plugged it in again, it made a steady beeping sound and the abbreviation SHDN was showing...
Unfortunately this can be a costly issue, try replacing your temperature probe first (red and white wires on control board). If you continue to get a SHUTDOWN error you will need a new control board. Make sure you have a water pressure regulator installed on your incoming water supply and that it is set no higher than 20 PSI, also check your gaskets and fan motor seal to make sure they aren't worn out and allowing steam to enter the electrical compartment.
Apr 18, 2011 | Baxter OV300E Stainless Steel Electric...
Water coming out oven no steam and it will not get to tempeture
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Jan 02, 2011 | Baxter OV300E Stainless Steel Electric...
How do I descale a Miele steam oven?
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
Jan 31, 2009 | Miele DG155-1 Steam Oven Single
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
