Question about Cell Phones
Need user manual for t289 radio - Cell Phones
    Problem Solver:
  • 5 Answers
Where i can buy a battery and antena for Motorola Talkabout T289 ...thanks
The antenna on this radio is a fixed item and was not sold separately. Your best option on the antenna is to locate a used radio for parts.
For the rechargeable battery you can check with www.wirelesspro.com. They may have what you need.
Best regards.
Jan 21, 2014 | Motorola Talkabout T289 (14 Channels)...
Kisigem@hotmail.com
Height and placement of your antenna determines range. In normal circumstances a two-way radio will talke line-of sight up to 2 miles. Any obstacles you have inbetween the two radios will shorten the range. Talking from inside to outside you can expect only 1/4 to 1/2 mi. range. Hold your antenna perpendicular to the ground (straight up) for the best range. Tilting the radio to the side can reduce range by up to 2/3s. (You'll need to do the conversion to kilometres).
Best regards.
Apr 27, 2013 | Motorola Talkabout T289 (14 Channels)...
Motorola Talkabout 200 - how do i set main channel only? i need to set for example channel 1 and subchannel 0 (1-0; 2-0; etc) but i can only set a main channel with subcode for example (1-1; 1-2; 1-38
Here is a link to the user guide for the T289. It is the closest we have fofound to the T200 guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
It may be of assistance to you. Honestly, we were thinking the early model T200 and T250 did not have the interference eliminator code., just 14 channels. However, if you are experiencing other numbers, it is possibly the code.
Best regards.
Jun 10, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
Need a manual for Motorola Talkabout250 --- do you have it?
We have been unable to locate a manual for the T250, however this T289 radio is very similar and the manual may be of help.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Best regards
May 19, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
T289 battery replacement. Does the clip have to come off the back before sliding down the U shaped black bottom?
No, but it might be handy to remove it. To remove it you would look at the front of the radio, and place a small screwdriver under the lip of the clip and gently pry up. However, you can remove the u-shaped bottom without removing the clip.
best regards.
Feb 01, 2011 | Motorola Talkabout T289 (14 Channels)...
Will the Motorola Talkabout T289 work with a Uniden Scramble? So far we can get the uniden to recieve a signal from the Motorolla but not vice versa
Here is a link to the user guide for the T289. http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
You might try setting the interference code eliminator to zero (off) and see if they match. If not, try each of the 38 codes individually until you find the one which matches the Uniden.
Best regards.
May 17, 2010 | Motorola Talkabout T289 (14 Channels)...
How to turn off motorola T289 two way radio
On your left hand side as you face the radio, there is a row of buttons. The top button is the power button.
Here is a link you can copy and paste for the owners manual. (Click T289 PDF in the upper right hand side of the page to download)
http://www.usersmanualguide.com/motorola/2-way_radio/t289
Jan 18, 2010 | Motorola Talkabout T289 (14 Channels)...
How do I open my Motorola talkabout T289 to replace the batteries ? Thank you
The black U-shaped sides, which are attached to the back, slide down and off the radio as one piece.
Aug 09, 2009 | Motorola Talkabout T289 (14 Channels)...
Users Manual on how to use
Motorola Walkie Talkie Code and Channel Setting
  1. Push and hold On/Off button. It will tell you Code & Channel
Note: You are now in the change mode
  1. Change Code - Push the talk button till handsets match Code then push monitor button to accept
Note: You are still in the change mode so you can change Channel
  1. Change Channel - Push the talk button till handsets match channel then push monitor button to accept
  2. To check repeat step 1 then push on/off button
Dec 19, 2008 | Motorola Walkie Talkie 2-Way Radio
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
