Question about Regency 4720 4724 4660c
Won't reset after alarm triggers
Regency 4660c
Why is my alarm going off intermittently after being locked for no reason throughout the night and day?
Could be a drop in voltage. Alarms sense voltage change to trigger. When you open a door or cause any component to draw voltage while the alarm is activated it will trigger. Apparently something is drawing voltage or causing it to drop while you car is sitting. your battery may be going bad and the voltage is dropping past the benchmark level of the alarm trigger and it is going off. It can happen if the battery is marginal and it gets very cold out or there is a short in a component causing voltage to change.
Feb 12, 2015 | Cars & Trucks
How to reset admin password on a regency silent nigth 4720 ?
The admin password needs to be reset from server side don't think it can be done from pad.. I might be wrong
Aug 28, 2014 | Home Security
Alarm reset
Yes, you can, but legally only a dealer can do that. It's easier to just find out what's triggering the alarm and fix that - usually it's a faulty door lock sensor that's easily replaceable for under $200.
Oct 03, 2013 | 2005 Kia Sorento
My 2004 Hyundai accent's alarm goes off randomly some time after the car is locked
The alarm system has a sensitivity control and it needs to be turned down. This cannot be a factory alarm system?
Jun 21, 2012 | Hyundai Motor 2004 Accent
Engine won,t crank.I checked starter, and starter relay, good.There is an alarm system.....How do I reset factory alarm?
If the starter turns the engine when you jump from the hot lead to the trigger terminal/ then no further testing is required except that it is possible that the solenoid on the starter may be bad. Usually though they don't go bad all of a sudden and you would have a few weeks where you needed to turn the key a few times before it would engage. You need to check what I mentioned before.
Oct 14, 2010 | 2002 Jeep Liberty
Alarm not beeping when doors are open. led on door goes red when door is opened and alarm box has red and green lights when alarm is actived but not chimes or alarm when doors are opened
When a zone has both red and green lights on, it means that it is in delay mode. That means when the sensor is triggered, the system will wait for a predefined time interval (30 seconds) for user to reset the trigger. During this time interval, the system will not beep or alarm. But after that, if user does not reset the trigger, system will go off.
User can reset the trigger from keypad or by remote.
Sep 05, 2010 | Skylink Group Skylink Security System Kit
Remote goes off continueouslly and unless battery cable remove won't stop. Also, vechicle won't start.
Some Jeep models have the ability to reset the alarm by following this procedure. Connect the battery cables and allow the antitheft alarm to trigger (usually horn honking and lights flashing). Use your ignition key to lock, unlock, lock and unlock the passenger front door. This should reset the system to be used normally. If your key fob is the problem, remove batteries to stop alarm trigger and have dealership test and/or replace fob. Hope this helps.
Aug 14, 2009 | 1997 Jeep Grand Cherokee
My car alarm triggered off and now my car wont start.
under the steering column on the left there is a fuse box there are three metal fuses larger than the normal fuse...there is a tiny hole it is the reset button for the theft detection...check the manual...should be around page 194 i think...you just stick a pin into the hole and should reset.you migt need the alarm code to release the lock on te engine.depends on what type of alarm it has installed...
Mar 12, 2009 | 1992 Lexus Ls 400
Alarm System
No it won't reset your alarm system. As part of the bit-writer program, anything you set or change in the alarm menu will remain the same. The only thing that can happen is if you have a DEI 520t back up battery, it may trigger the alarm upon re-connecting. No biggy.
Feb 25, 2009 | Viper Vehicle Parts & Accessories
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Regency 4720 4724   4660c Logo
54 people viewed this question
Top Regency Home Security Experts
Lawrence Oravetz
Are you a Regency Home Security Expert? Answer questions, earn points and help others
