Question about Magic Chef Dryers
Need to rewire a furnace with a transformer
Thermostat transformer wiring diagram
  • 2,113 Answers
Http://www.electrical-online.com/thermostat-wiring-explained/
Posted on Nov 26, 2013
Intertherm wiring diagram for model number MGHA-056ABFC-05
you have a 24 volt shorts check your thermostat wires to see if they are frayed or if they are touching anything. Check your outside wires also go to the thermostat.
Jul 12, 2014 | Intertherm Heating & Cooling
My rv furnace want start up i changed ac units new don't have the relay box build in it how do i rewire the furnace ?
Shooting from the hip here, but look at both the new and old wiring diagrams. Chances are that the new unit has terminal leads that would connect to the old units' relay/control box and you simply need to install the old box on the new A/C by connecting to the correct terminals. beyond that, you can build your own relay setup if you understand wiring diagrams. If you don't know wiring, I'd recomend taking to an RV shop, as you can damage either the A/C or the furnace or both if wired incorrectly... Hope this helped!
Mar 26, 2013 | Heating & Cooling
I am having trouble with rewiring the air handler transformer and thermostat wires
Here is standard wiring on a low voltage transformer:
"r" on transformer goes to "r" on thermostat (use red wire)
"w"on transformer goes to "w" on thermostat (use white wire) (this is heat)
"y" on transformer goes to "y" on thermostat (use yellow wire) (this is cooling)
"g" on transformer goes to "g" on thermostat (use green wire) (this is the fan)
"c" (if used) goes to "c" or thermostat
"o" (used only on a heat pump)(orange) (reversing valve)
note: on most thermostats if you have an rc and an rh, they both must be jumpered together and use them as "r" (red)
Jun 23, 2011 | Heating & Cooling
On my therostat it show and talks about the R wire and the Rc wire. What is the differet?
If you would have a two transformer system..... The power wire from the furnace transformer would hook up on R and the power wire from the Air Conditioner transformer would hook up to Rc....
BUT most systems now only have one transformer...... So if you are using this thermostat you will need to put a jumper wire from R to Rc. So the Air Conditioner will work. Furnace is the source of the transformer. R/Rc,W,Y, C, on the Thermostat will Hook up to R,W, Y,C on the furnace and Two wire from the Air Conditioner would hook up on Y and C on the furnace.....Good Luck.
Apr 02, 2011 | Heating & Cooling
I need the wiring diagram to wire a thermostat to the outside unit. Which wire goes where ? My Thermostat has four wires, green, red, white, and yellow. My Outside unit has three wires that are not...
The thermostat wires are this, Red is 24 volts hot, Yellow is cooling, Green is fan,indoor, and white is heat.The outdoor unit wires up to the indoor units terminal board, not the thermostat.The red will go to the R or red 24 volt wire at the furnace.The yellow goes to the yellow terminal at the furnace. You should only have 2 wires to connect at the outdoor unit. Try capping the blue off.It may not be used unless this is a dual transformer unit which you will need a tech to come out and rewire the furnace to make the outdoor unit a 2 wire set-up. This can be very complicated if this is the case. Connect these wires like I have said to the indoor unit, and it should work fine. Please keep me posted. This is only low voltage, so don't let it scare you. If nothing works, I would say that the blue wire outdoors is the 3rd wire for a 2 transformer unit, and will need to be rewired at the indoor unit for it to work, this I would have to be there to do.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Feb 26, 2011 | Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Installed dayton nat gas hanging furnace in garage and have 2 wires dont know where they go one came from the back side of the transformer it was twisted with the other wire
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Dec 11, 2009 | Dayton Gas Furnace Heater
Can you give me wiring diagram for honeywell thermostat RTH6300B1005-0825
http://customer.honeywell.com/TechLit/pdf/69-0000s/69-1717.pdf that is the best I can give, as wiring is dependent on the type of equipment that you are controlling with the thermostat. Be sure to cut your power supply off before you start or you'll need a new transformer and a wiring diagram for your furnace too.
Oct 25, 2009 | Honeywell Electronic Programmable...
I have a intertherm model 9007590 AC unit. The condensing unit was changed to a unit that has a common wire and a y terminal and the old condenser unit had three wires at condensing unit. I can't get it to...
the unit with3 wires was set up as a dual transformer the new unit is single transformer system. it needs to be rewired at thermostat,furnace,and ac
Jun 27, 2009 | Heating & Cooling
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Dryers Logo
50 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Roderick Scott
Roderick Scott
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
