Question about Philips Magnavox 15MF400T 15 in. LCD Television
Magnavox 15 Turn on TV or Monitor. Works fine for about 20 minutes, then shuts off. Turn it back on. Works fine for about 10 minutes. Turn it back on, cycle shortens until it will not turn on. Leave off for about 10 minutes and the cycle repeats. I think something is overheating. Where can I get this fixed.
  • Anonymous Feb 12, 2008
    Same Problem.
    Unit works for 15 minutes when first turned on, but then will only stay on for 2-5 minutes thereafter. I too think it is overheating and have bought a replacement because it is so annoying...I may take off the back of the unit to see if the internal debris / dust balls are perhaps causing the issue, but I doubt it.
    Tried replacing plug to power supply - No Luck (Light is still green on power supply (after it shut off by itself, so power to TV / Monitor is most likely not the issue, or my issue )
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Posted on Feb 11, 2008
Magnavox 46" LCD TV shuts itself off after a random amount of time.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Apr 14, 2014 | Magnavox 46mf401b/f7 46 Hdtv, Lcd 1080p...
Volvo 960 AC problem
TX valve freezing?
Jun 22, 2012 | 1997 Volvo 960
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Tv shuts off
check to see if tv is set on a timer to turn off?
Mar 21, 2009 | Philips Magnavox 20MT133S 20" TV
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
Magnavox 26mf23id/37 will not stay on
Replace capacitors 2079 and 2080 with 1000 uf, 50 volt caps. They are on the power PCB at the top as you look at the unit from the rear. Barneyluc.
May 23, 2008 | Televison & Video
Magnavox lcd tv 15mf050v/17
I put heat-sinks on U14 and the regulator above it and the TV has been running fine all day. Always shut off after 14-30 minutes before. Heatsinks were just 1/2" x 1" metal strips with silicon thermal compound that I taped up to hold in place to temporarily test, as it is obviously a heat related problem.
If you try it and it works for you, post it here.
mwl777us@verizon.net
Dec 11, 2007 | Philips Magnavox 42MF521D/37 Television
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
TV turns on for about 10-15 min then turns off
Sounds like a tuner section problem. When you are playing a DVD. You are only using the audio video circuit of the TV. Something like a monitor. But when you go back to TV mode... You are now in the tv tuner circuit. And your problem lays there. I had a mouse **** on my tuner section of my tv and it caused the same problem. Yes mice do ****...
Aug 18, 2006 | Panasonic PT-47WX53 47" Rear Projection...
Philips Magnavox 15MF400T 15 in. LCD Television Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
