Question about ZT Group CISNET A7050 PC Desktop
My computer says I need a mixer device to rip CD's, And to hear sound for anything.
  • 413 Answers
Actually it means your sound driver has crashed dont worry ,run regcure.exe first and reinstall the sound driver
Posted on May 08, 2009
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
No sound
If you have the green bars, check with headphones. Then with a different pair of speakers. Make sure it is not muted. There is a device choice option in case you have more the one device driver installed.
Dec 25, 2012 | Computers & Internet
To reduce background noise from an audio mixer
when you say background noise I assume you mean the inherant noise that electronics produce. the the first thing to do is to make sure that all you input connections are shielded type, you don't need to spend money on gold plated connections, but do buy cables that are made with stranded wire and of decent size, bigger (fatter) is better when it comes to minimizing high frequency losses. Next, calibrate your inputs one at a time with a 1000hz signal that is 0db inn level. You can find this signal online through a search. you can also buy small plug in devices that produce this signal at 0 db (that is Zero Decibles) this is a common reference for "consumer" grade mixers, If you can't or don't want to spend any money on this you can use a signal from any tone generator, and some mixers have them built it. If you don't have any of the former, here is what you can do. turn all you mixer controls to 0 (zero) detent. in other words, flat, no treble, no bass, no midrange. on your inputs there should be input level knobs, these woule be set to thier lowest positionn if using a line input signal. if a microphone that level would be different, but wait on that for a bit. now have all you input knobs (or sliders) at minimum level. Now turn on your amplifer (if your using one) or what ever you monitor the output with. Headphones is a good choice as you can hear everything.
You should hear nothing. (nothing is supposed to in the inputs yet) if you hear noise take note of what it sounds like. turn the sound output level out (if headphones, turn up to a high level) and listen again. is the noise white (hiss) or hum (low freqency) if you have no noise, you have a good mixer and that is what it should be.
No plug in your first input, this is your choice but I would suggest you plug in microphone, now turn it up to the point where you can hear your own voice, you should hear just that, and maybe anything in the backgroud (furnace, tv, etc_) the quieter your environment, the better you can adjust this. Remember you will now need to turn up the input level. If you have meters you should be able to adjust the input to register in the green without turning red, a litlle yellow once in awhle is ok.
If this is quiet and clean you are ready to move on. turn that mic down to zero, but leave the input where you set it.
now plug in a line level source (your tape player,/cd player/ but don't use your computer as a source (yet). without anything playing on your machines you should hear very little noise in your headphones, if you hear a lot of noise you have bad cables.
Now play something through the tape/cd player, what ever and turn up the slider (not the input) this should give you a level,again in the green, with a little yellow, NO RED
once finished with this turn it back down and go to the next input. this time plug in your computer which most likely is coming from the green jack on the back (or front) of your PC/Mac or whatever. computers are very noisy machines, and just being close to one is sometimes enough to cause noise in a high gain system. anyway, plug in your computer and listen, you should hear some noise and I'd be surprized if this wasn't the source of your problem. make sure your volume level on the output of your pc is set to maximum, this will give you an advantage when recording. now turn up the slider on this input and listen for the noise level. good cables are important here and also the price of your computer may be reflected here as well since more expensive machines are better filtered and therefor produce less noise.
play a sound file (windows audio samples are noiseless and clearn) so use them if you can find thiem, look in your music folder for the sample files
You may hear some noise but your mixer is now set up at optimum and should give you nice sound if it is a quality mixer, good luck, Keith
Mar 24, 2011 | Audio Players & Recorders
I can't hear sound from my PC when I'm using the mixer. I plugged it in with the USB to the computer and tried to record using Cubase 4 LE. I seem to get sound in, but i can't hear any sounds from the...
In the "Sounds and Devices" of teh control panel under the Voice and also recording tabs amke sure the 2442 is selected instead of teh computer internal audiop system.
Feb 18, 2011 | Behringer XENYX 2442FX Mixer
I can not hear a voice on my computer there is a error that  there is not active mixer device
For sound or audio errors, please reinstall the audio driver using your computer Driver CD.
Jun 15, 2010 | Compaq Audio card Sound Card
I'm having problems setting up my numark tt1625 turntables with the mixer. I can't hear any sound even with volume on full. do I need an amp or is the equipment broken?
Double-click the Volume Control icon (beside your computer's clock, on the System Tray) to open the "mixer". Ensure that you have no "sliders" that have been set to "zero" ("no sound").
Connect the turntable-output to the "blue" (audio-in) socket on your computer's sound-card.
If you get no sound, move the connector to the "pink" (microphone-in) socket on the computer's sound-card, and try again.
Nov 26, 2009 | Nu Mark Numark (CD2CD) CD-RW Burner
Audio driver not loaded
You need to install the VIA drivers from the Mainboard driver CD first, then the Audio driver on the same CD. Do it in that order!
Mar 29, 2009 | Soltek SL-75FRV Motherboard
Not able to record onto Adobe Audition 1.5
Sounds like you do not have your audio recording source set correctly.  If you're recording from a file on your computer or a CD via the CD-Rom drive of your computer, you need to probably set the recording to either "Wave" or "What you hear", one of the two.  The "What you hear" can be easiest, but then again, if any other sound comes accross your computer at the same time, you'll end up recording that as well, so it's best to stick to "wave" if you can... or make sure all Windows sounds are turned off (Audio settings ->Sounds ->Select "No Sounds" as the theme).
Oct 25, 2008 | Adobe Audition 1.5
No active mixer's
Hello annointed,
The mixer should have installed during the install of your audio software.
If you have your Acer CD you can load your CD & look for the driver folder & open it. Find Audio or Sound folder.
Re-install your driver software.
You can open the link below that will open Acer's PDF file that contains your audio software. Depending on which sound device you have in your notebook.
Acer sucks at maintaining the correct drivers for their model no#.
Though you can find the Aspire 5570-2609 notebook, Acer does not list their driver's as 5570-269. They only list Aspire 5500-5570. For the 5570 click here & goto pg. 2
Audio driver v.5.10.0.5273
Windows XP AS3680_Audio.zip
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205570.pdf?CFID=40052&CFTOKEN=54644383
For the Aspire 5500 goto this link:
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205500.pdf?CFID=40052&CFTOKEN=54644383
Page 2.
5500Z - Realtek Audio Driver v5.10.0.5820
Windows XP
AS5500Z_Audio.zip
Mar 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Sansa e280
I have never heard of that...but it sounds like your device may have automatically sync the songs to your device..most of the time whenever you plug a device to your computer it automatically start the syncing process...To isntall the windows installer you need to go http://windowsupdate.microsoft.com/ and get all the latest updates available for your computer..should you need further assistance, please contact me...
P.S. Please rate accordingly...
Thank you
Computerrep
Feb 08, 2008 | SanDisk Sansa E280 MP3 Player
ZT Group CISNET A7050 PC Desktop Logo
41 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
