Question about Klipsch Promedia 2.1 Thx Computer Speaker System
Lost sound in left channel?
Lost sound on left channel. Speak ok, connection ok. No obvious burn spots on circuit boards. All caps intact. Any other suggestions to check?
    Genius:
  • 1,198 Answers
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Posted on Nov 27, 2013
I have a Mitsubishi TV model WD-65C9 and yesterday I heard a pop sound and the screen went black but there is still sound. Is this just a lamp bulb issue?
That pop noise was a so called "CAP" capacitor letting (they actually blow up) go on a circuit board, open the TV cabinet up and look carefully for a burned spot on the circuit boards, it will be small, when you locate that board it may fix the TV is you replace the damaged board.
Mar 23, 2017 | Mitsubishi Televison & Video
I Have a Marshall Amp and it had blew a circuit board that attaches to the fan so i replace the fuse and circuit board and now it turns on and registers the guitar cause the lights inside the amp go on...
It is what caused the fuse to pop that concerns me.
You did the correct thing looking for the source of the pop.However seeing any type of winding / coil that looks to have overheated is always a concern.
A small amount of discouloration is acceptable but should always be checked as they can cause much more damage if allowed to overheat and or short.
Many coils / transformers etc can be had off the shelf so to speak so I would start by getting a schematic and seeing if there is a value on it to measure against. or maybe from the coil itself.
test that first !If its OK then check the amplification stages.
Injecting a signal and tracing it is quite often a simple method to find out where the signal ends or is disrupted
Oct 05, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
My dynex tv wont turn on! the strom knocked out our power, now the power is back on the tv wont turn on from remote or tv power button.
Lightning is a weird beast, and can do strange things to a TV. Sounds like the set took a hit. If there is a fuse then check it on a volt-ohm meter for continuity while it is out of the circuit, and if it is an open circuit, replace it. If there is a circuit breaker, then reset it. If these don't work, look for obvious scorching on the circuit board (assuming you know how to avoid electricution, otherwise do not touch). Lightening can literally jump around on a circuit board, so there is no way to know what part of the set was effected by the strike - the lightening will not always burn out the first circuit it touches, but will burn out something further into the circuit. The most obvious place to look is around the transformer and rectifier circuits. If a capacitor was hit, it may be swolen or discolored; resistors will scorch, and the worst thing is that transistors and IC's often show no damage - in fact, any part might be burned out and not show visible signs. If nothing is obvious (like scorch marks) and the fusing is intact, there are too many possibilities to begin listing them all. The fact that it won't turn on at all sounds like it is probably a power circuit, but, not necessarily. FYI turning a set off during a lightning storm does not protect it, you have to unplug the AC power cord and the line that feeds the signal into the set. Even circuit protection devices (lightning arrestors) may not protect against a close strike. Maybe the techs at Best Buy can supply more suggestions (Dynex is their brand).
Aug 29, 2011 | Dynex DX-L42-10A 42 in. LCD TV
My 2005 Kia Amanti suddenly lost all audio on stereo system. It shows the channels but has no sound. CD player no sound. All fuses are ok.
Ur audio cable probably got pulled out or cut, if intact, there is a sound ic that gets affected by short circuiting and can be replaced.
Jun 13, 2011 | 2007 Kia Amanti Sedan
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Vsx-816-k left channel cuts in and out.
You likely have a cold solder connection on the circuit board. Inspect the board for loose connections for the left channel - use a non-conductive pointed object and poke the board on several places while the unit is power-up. Be careful not to get electrocuted. Compare it to the right channel circuit - they are almost identical. If the unit recovers the left channel while poking, then you have found the bad connection. Re-apply solder to that junction - make sure you've dis-connected the power and dis-charged all caps before you touch and repair the circuit board.
Nov 09, 2010 | Pioneer VSX-816-K/S Receiver
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
COMBINATION OF PROBLEMS WITH MODEL 25 HOT POINT SIDE BY SIDE. UNPLUGGED IN FREEZER FAN SO REFRIDEGERATION UNIT WORKS AND TOOK OUT ICE/WATER CHUTE LIGHT SO WATER INDOOR DISPENSER WORKS. LOOKED AT CIRCUIT...
i think you answered your problem / sounds like the board. some times you can smell the burn and some boards have clicking sound . / from what you have stated . i would replace board. mm the burn is the price of the board .. mm
Dec 03, 2009 | Dryers
Right channel won't play on stereo amplifier
In old stereos the first things I look at are output transistors, solder joints and electrolytic capacitors. If you know how to solder, bad solder joints are pretty obvious. If you need a tutorial on how to spot bad solder joints, look here.
http://www.kingbass.com/soldering101.html
As for bad caps, look here. The info is aimed at computer motherboards but still helpful.
http://www.badcaps.net/pages.php?vid=5
Dec 06, 2008 | Audio Players & Recorders
Klipsch Promedia 2.1 Thx Computer Speaker System Logo
142 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
richie46
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
