Tv displays format invalid
Tv displays invalid format when i try to plug in my apple minimac via vga port
    Problem Solver:
  • 10 Answers
Hi matthew ife, a possible solution to this problem is to click on System Preferences and clicking on Displays and adjusting the Screen Resolution of the Mac Mini itself so your TV can display your screen.
Posted on Nov 27, 2013
Emerson lc320em2 how do we hook it up to netflix
The Emerson LC320EM2 is not a Smart TV. To display Netflix content, you can connect the TV to your computer via the VGA port on the TV. Then use the TV as your monitor; this may not work with HDCP content. To do this, turn off both the TV and the computer before connecting the devices. Then turn on the TV and set it to the VGA input (PC) before turning on the computer. (Note: you may have to enable the port in the BIOS on some laptops.) If your computer doesn't have a VGA port, try a DVI to VGA adapter. (This may not work with some video cards that only have digital signal output. Look at the port and make sure that the cable/adapter doesn't have more pins than the port.)
Alternatively, get a set top box with Netflix support. (Some Blu-ray players, the Roku box, Apple TV, or the WD Live Hub all have internet connection options and support Netflix. All will support a wired ethernet connection; some models will require a dongle to connect to a wifi network.)
Once you have the set top box, connect the TV to the box via a HDMI cable (purchased separately for most units). Connect to your internet connection and then log into Netflix, These steps will depend on the unit; please add a comment with your source of the Netflix content.
I hope this helps.
(I have an LG Smart TV; it is slow to find the wireless network when started. So expect some wait time before you can sign into Netflix.)
Aug 23, 2012 | Emerson Televison & Video
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
I am trying to connect an acer one notebook to a beko 32" flatscreen and everytime i plug the vga lead in the laptop screen goes black an the tv says no signal,,what am i doing wrong??
It could be a no. of things:
- Wrong input selected via the TV
- The VGA input on the TV is turned off
- Problem with the VGA cord
- Problem with either VGA port
there the basics, if there all great and it's still no working, try setting your Computer display to EXTEND rather then projector only, then play around with your graphic output settings.
UPDATE all your Drivers and check all your cables. PLUG IN YOUR LAPTOP, yes it will make a difference to the way the graphics card operates.
Hope this helps.
Mar 05, 2011 | Acer Aspire One PC Notebook
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 11, 2010 | Olevia LT32HVM 32 in. LCD Television
I'm trying to plug my laptop into a tv to display my desktop and I can't seem to do it. I got a vga adapter and cord that is plugged into both the tv and laptop. What am I doing wrong?
The 13" White MacBook 2.0GHz has a mini-DVI out port. The adapter you need is
Apple Mini DVI to VGA Adapter
On the TV side, more information is needed. You need to specify what ports on the TV you are using for your signal, and what kind of adapter cable you are using. I suspect this is the component or connection where your problem lies.
May 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook - Lg TV
Take a look at these discussions:
http://macosx.com/forums/hardware-peripherals/304718-connecting-macbook-lg-hdtv-rz-32lz55.html
http://discussions.apple.com/thread.jspa?threadID=1398546
Maybe a solution.
Good luck.
K.
Jan 04, 2010 | Apple MacBook Mac Notebook
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Dec 12, 2009 | Televison & Video
Trying to connect a pc to the tv with a vga cable but i get an invalid signal on sceen.
Make sure all power it off,and unplug,bfore plug in the PC in.Reboot the computer,might check if pins in VGA cable not damage plug in the Tv VGA video port.
Nov 23, 2009 | JVC HD-56G787 Television
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
43 people viewed this question
 Grubhead
Grubhead
