Question about Boost Mobile LG Venice Smartphone with Accessories - -
Unable to connect to the proxy server
Cant use wifi
Why am I not able to connect to any websites and why am i getting an error that states "proxy server not responding".
I never use proxy settings. You could try turning it off and try. You almost certainly cannot use someone else's proxy server settings.
Feb 26, 2015 | ASUS Tablets & eReaders
Unable connect server
i think there is a proxy sever use ultra suf proxy
ultrasurf.us
Jan 06, 2014 | Facebook Social Network
Unable to connect to the proxy server A proxy
This is a brain-dead system default setting from Microsoft. If your company/network requires you to use a proxy server, they can make it happen invisibly to you. There is nothing wrong with turning it off except that your connection might slow down if there is a proxy on your network and you don\'t use it. Proxy can cache (save recent pages) and/or restrict your access (filter porn sites). Filtering should be invisible or not configurable by users. The MS default is just plain wrong.
Oct 11, 2013 | Google Chrome
In webfreer I cant connect through the net, the error is: A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a...
solution is very easy..open webfreer..open settings..on the left side click extensions..update extensions..and enable secure https proxy
Aug 03, 2013 | Google Chrome
Shows unable to connect to the internet. please check your settings
if using home wifi and you have OpenDns with filtering enabled, it will not work. Opera Mini uses proxy servers.
Apr 12, 2012 | Cell Phones
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Sep 19, 2011 | Google Chrome
The Proxy server is refusing connection,. Unable to connect to the Proxy server. Error 130 (net : Error_Proxy_Connection_Failed)
Google Chrome may not be using a proxy from your ISP odds are that it is not so you will have to go into the tools and options and then select connections section and disable the connection for proxy server usage just un check it not to use any proxy servers that is what is going on. I hope that this assisted you. Thanks for using FixYa! John
Apr 13, 2011 | Google Chrome
How to hook up to wifi
So you see your wi-fi connection is open??? Have you fixed this problem yet??? fairly simple... it shouldn't be as difficult as the page you were referred to above:)
May 20, 2009 | HTC Touch Pro Smartphone
Installation problem
problem in the firewall ,ip address, proxy server, and antivirus if there all then change it disable the firewall, proxy server, any antivirus and check the ip address is give right or wrong
Feb 15, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Boost Mobile LG Venice Smartphone with Accessories - - Logo
79 people viewed this question
Top Boost Mobile Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Boost Mobile Health and Beauty Expert? Answer questions, earn points and help others
