Question about Miller Welding Tools
Miller 225 Dialarc mid range weak
High range works great, mid range can't form a puddle. I changed the reohstat stiil have the problem. Please help diagnose. Thanks
    Genius:
  • 1,198 Answers
I presume you are using a smaller rod on the mid range? Check lead connections for corrosion.
Posted on Nov 26, 2013
3 Suggested Answers
  • 2976 Answers
SOURCE: How to change wiring from 480 V to 220V connection
Here is the link for the manual. You will need the exact model AND the serial number to get the correct manual.
http://www.millerwelds.com/service/ownersmanuals.php
Posted on Feb 05, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
I have a Miller Bobcat 225. It will not start and run with out pouring gas into the carb? I have changed fuel line and filter? Help!!! Please
Check fuel pump and check carburetor bowl for stuck needle. If fuel was left in engine stuck needle or plugged jets. Confirm that choke is fully closing when cold.
Hope this helps?
Fuel Pump.
Jun 26, 2017 | Miller Welding Tools
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
I need a manual for a airco welder. Stock number1341-0266. Serial number hk220507. Thank you.
This was made by Miller. It is the same as a Miller Dialarc 250 ac/dc.. Go to www.millerwelds.com, then "service", then "owners manuals" then "search", and scroll down until you find the dialarc.
Apr 22, 2015 | Welding Tools
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
Wire speed does not match the digital read out
This is dificult to know unless you in reality are measuring and timing the wire fed.
Does not show whatt brand it is, but mostly the problem is the potentiometer (reohstat). Change it if your machine is more than 5 years old.
Jan 11, 2011 | Miller Welding Tools
I have a Miller Synchrowave 180 sd and have been having difficulty welding aluminum. Can you please help.
I'm not sure what it's doing to know why it's not working but if I was trying to weld aluminum I use 100% argon in ac with high frequency continuous and a 9 second post flow with 5356 crown weldind rod.
Jun 05, 2010 | Miller Welding Tools
Sudden High and Low Oil Pressures
yes it might work if u flush it, give it a try
May 27, 2009 | 2000 Dodge Ram 1500 Truck
Miller dialarc hf. foot pedal does not work
check pins a and b thats for the contacter closer. short those two out in the machine. and see if it.makes the hf come on.
Apr 05, 2009 | Welding Tools
Feb 05, 2009 | ARC Welding Tools
Welding Tools Logo
48 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
