Question about Ingersoll Rand 2475N5-P 80 Gallon Vertical Electric Air Compressor - 5 175 PSI
I just bought a aftermarket 5 hp motor, but not sure which was it is suppose to spin?
  • Ingersoll Rand Master
  • 10,291 Answers
There should be a rotation arrow on either the case of the compressor near the pulley shaft or on the pulley itself.
Posted on Jan 29, 2014
Carrier Blower Motor not free spinning
Hello, It sounds like the pin, in the middle of the rod has fallen out.
Jun 04, 2014 | GE Carrier 3/4 Hp 115v Blower Motor...
Which way does it spin?
Put it on. The big pulley is also a big fan. So it should blow air on the pumping unit. This is it. If it spins in the wrong direction change the polarity. If you look close you should see somvere a rotation direction indicator .
Nov 26, 2013 | Ingersoll Rand 2475N5-P 80 Gallon Vertical...
Wa50t54w1 elba
this can be a motor control fault, and sometimes a fault with the motor itself, test motor windings for equal resistance, and check motor physically for wear / damage. replace motor controller.
Oct 24, 2013 | Fisher and Paykel IWL12 Top Load Washer
Getting code LE supposed to be motor overload according to manual do motors usually go bad or could it be in circuit board control
Motors rarely go bad. A Hall sensor, clipped onto the motor, can go bad, and is rather easy to replace. (the whole motor is easy to replace, for that matter) LE codes can also be caused by bulky loads, like quilts, sleeping bags, pillows, etc., being washed using a high spin speed. Always use a low spin speed for those type items. So, unplug machine, and replug. try another load, making sure to use appropriate spin speed for the load. If LE re-occurs, change the Hall sensor. (It has at least a 5 year part warranty on it in the US) To change Hall sensor, unplug machine, remove back cover, remove bolt from center of motor rotor, remove rotor, remove wire clamps and ground screw, remove 6 bolts holding motor stator (with all those electric coils), unplug wires from stator and sensor, unclip white plastic hall sensor from stator, replace hall sensor with new one, re-assemble. Sounds like a lot, but on a difficulty scale of 1 -10, it's only about a 3.
Jul 26, 2010 | LG WM1815CS Front Load Washer
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
MY FAN ONLY BLOWS HARD ON 4 AND 5 AND NOTHING ON1-3
yes it sounds like you got a bad resistor card,,,not sure on aftermarket parts for it,the resistor card is right in the blower motor housing,2 bolts,screws easy,,
Oct 10, 2009 | 2003 Pontiac Grand Am
Kenmore model 110 will not agitate or spin............ it will fill with water and drain ........but will not spin or agitate.............. you can hear the motor runniing
You have a broken drive coupler. This is a very common part that fails. This is the piece of rubber between the motor and the transmission. Lean the machine back and reach behind the motor and you will be able to feel the rubber coupler wiggle. This is supposed to be tight. Another sign of it being bad is rubber on the floor under the machine. I replace at least 5 a week. This is your problem for sure. The part number is 285753. You can order this at sears.com or your local parts store should have it in stock.
Nov 21, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE TOP LOAD WASHER - MODEL # 11022422100
hi. thanks for the question . i would check the lid switch ,on that washer. it could be the problem thanks. the appliance doc
Oct 05, 2008 | Kenmore Elite HE4 Electric Dryer
Fisher & Paykel GW711
is it making a humming sound at the spin,is it draining you may have a blockage try turning the black fan on the pump front right underneath.hope this helps.
Mar 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Heavy Duty Speed Queen top loader, HA 4011-3062, with a slow spin
I have a related problem and I just learned on the net that the Vbelt is supposed to slip in "idle" mode while the water pump will do more work.
It is also supposed to slip slightly while speeding the spinning up so as to not cause motor overload.A kind of half clutch function that allows for slipping. This slipping is controlled by the tensioner.
My guess is that your machine's v belt slips too much and thus does not spin fast enough. You replaced the belts, I would look at the tensioner now.
Feb 09, 2008 | Washing Machines
Ingersoll Rand 2475N5-P 80 Gallon Vertical Electric Air Compressor - 5 175 PSI Logo
79 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
