Question about Hotpoint Kitchen Ranges
How do i take apart a hotpoint range RGB745WEH7ww to get bugs out of the clock
I have a Hotpoint R B757 something behind the clock rattles, It's not the clock because I have it off? Could it be the relay or thermostat? Everything works.
This may be a silly answer but you might try to just take out the few screws from behind the top panel where the clock is and see what's loose behind there. Unplug the stove first of course.
Feb 23, 2015 | Hotpoint RB757 Electric Kitchen Range
I have a hotpoint electric ignition gas stove...digital clock is acting funky so I want to diconnect it....how?
If you disconnect it, you will loose functions to the oven so you will need to replace the clock/control board. Here is the part to order.
Feb 09, 2013 | Hotpoint RB757 Electric Kitchen Range
I need to replace Door Gasket on a Hotpoint Range and I'm not sure if I need to take the door apart or what?
This page has the service manuals for various models; there are about 40 different ones listed. Hope that helps!
http://www.retrevo.com/samples/Hotpoint-manuals.html#Range
Oct 05, 2011 | Hotpoint RB787 Electric Kitchen Range
How do i turn the pilot light off. I want to use a bug fogger in my apartment and i want to temporarily turn off the pilot on my stove
This model should have pilotless electronic ignition.If you hear clicking when you light the burners , it is electronic,. Also , open broiler drawer and turn on oven .After a few seconds do you see a glow start?Thats your electronic oven igniter confirming you have no pilot.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
The burners work, the broiler works but the oven doesn't go on! Model RGB745WEH7WW Can anyone help?? I'm having guests for dinner!!
This could be your lower oven heating element, but that won't help for dinner tonight. Make sure your selector is in "bake" and not "broil" but you probably already checked that.
It could also be the thermostat, but that can't be fixed immediately either.
Sep 11, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
Hotpoint oven and broiler won't turn on
Since both broil and bake do not work you must replace the ERC (clock).Part number WB12K0020 about $150.00.
Apr 01, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
Apr 12, 2008 | Hotpoint RB787 Electric Kitchen Range
Oven clock replacement
If you are sure you have the correct clock for your model have followed instructions completely, tape up loose wire ends individually and give it a try.
Sep 07, 2017 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
27 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
