Question about Ingersoll Rand 2475N5-P 80 Gallon Vertical Electric Air Compressor - 5 175 PSI
Which way does it spin?
I just got a new 5hp motor, the motor i got is an aftermarket which way is it suppose to spin?
    New Friend:
  • 20 Answers
Put it on. The big pulley is also a big fan. So it should blow air on the pumping unit. This is it. If it spins in the wrong direction change the polarity. If you look close you should see somvere a rotation direction indicator .
Posted on Dec 10, 2013
I’m looking for a carburetor for an Earthquake rear tine tiler with a Briggs and Stratton 5hp motor. It’s a model 5020 with serial # 201026
Chances are the Chinese produce a replacement and ebay is likely to list them alongside new and used genuine Briggs units. Amazon too are likely list some.
Might be worth trying freecycle too.
You might prefer to pay full price from a Briggs dealer which can be found almost everywhere.
Jan 29, 2018 | Briggs Garden
I just bought a aftermarket 5 hp motor, but not sure which was it is suppose to spin?
There should be a rotation arrow on either the case of the compressor near the pulley shaft or on the pulley itself.
Nov 26, 2013 | Ingersoll Rand 2475N5-P 80 Gallon Vertical...
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
My Coleman Powermate 5,000 (6250 surge) CAN drive my big old Sears 5hp 220 compressor, (that's it's job), since there's no 220 in the garage. BUT, there's been a number of time'
What you are describing sounds like a load of bad fuel, the white smoke may be due to that. I suggest you drain and check the fuel, let it settle out and see if any water appears at the bottom of the sample.
May 18, 2012 | Coleman Powermate Portable Generator...
K750 cut off saw three new air filter,gas filter,spark plug saw loses power after 15 sec of hvy cutting
Piston rings are gaulded or stuck, easy to change and fairly inexpensive if you buy aftermarket parts on ebay. I believe piston, rings, and cylinder (if you need it) for less than $100.
Aug 25, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Need to change out bearings
You will need a 7/16 inch open ended wrench, a bearing puller, a phillips screwriver, a 12" peice of metal electrical conduit, and the bearings.
dismantle wet end of pump down to the impeller. Remove the shaft cap at the back of the motor(small circular cap in back). use 7/16" wrench to hold the shaft under the cap whiile spinning the impeller counter clockwise untill impeller is off. using a 1/4" hex driver remove the 4 through bolt located at the rear of the motor. seperate end caps on motor housing to access the bearings. use puller to remove. use the 3/4" conduit to tap new bearing into place. Reassemble unit.
Make sure you have an o-ring kit for this pump first
Aug 30, 2010 | Waterway 5HP Executive 56 Frame Spa Pump...
How to conect 3 phase motor 9 yellow wires from t1 to t9
There is no neutral on 3 phase. They are all power wires. If you try hooking up a 3 phase motor to single phase power it won't work.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
I'm trying to figure out how to wire a 5hp motor
Go to the website for the motor manufacturer- it will show how these capacitors are to be wired. You'll need the motor model number.
Sep 22, 2009 | Air Tools & Compressors
I have a 5hp briggs motor with 2 pulleys off the side. One spins counter clockwise the other spins clockwise is there a way to change this so both would spin the same way? Its mounted on an old tiller and...
generally these pulleys do not reverse, one drives the wheels, the other drilves the tines some models they rotated in same direction and others towards each other
Jul 07, 2009 | Garden
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
Ingersoll Rand 2475N5-P 80 Gallon Vertical Electric Air Compressor - 5 175 PSI Logo
57 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
