Question about Dishwashers
Circulation pump on my Miele dishwasher
My Miele 595 is at least 10 years old. The water intake light goes on as the machine shuts doen during operation. I've had Miele technicians out and they replaced a part and a relay and it worked for a few days. In consultation w/tech support at Miele, they believe that the problem could be the circulation pump and said that itcosts around $800. Does the diagnosis sound correct? I might be able to buy the part from another source for less, but would like to make sure that there is a high probability that this is the actual problem. Thanks for your input and I realize that you are limited in your opinion due to not seeing the acual problem.
  • 83 Answers
Miele makes a special tool that you use to free up circulation pump.The price for that pump is about 800-900 dollars.Call miele and ask for that tool.
Posted on May 09, 2009
I just experienced a F14 error. Repairman came and put the machine in diagnostic mode and came to the conclusion that the circulation pump is the reason - repair cost is approx 800 USD. Sucks for a machine that is 5 years old.I will buy a second hand machine and replace the pump myself.
Posted on Jun 26, 2012
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele dishwasher model G858 water will not circulate and the intake / drain code flashing? Does anyone know what needs to be replaced?
when you start a cycle, your machine should drain for 30 sec, fill with water, and then the circulation pump should come on. your water level should be up to the handle on the filter in the bottom. if you drain, and fill to the handle and then the intake drain error comes on, your circulation pump is stuck. if it does not fill to the handle, you may have a problem with the inlet valve.
Jun 02, 2012 | Miele 24 in. G858SCVi Plus Built-In...
F14 fault on Miele dishwasher
Hi
F14 means a fault on the heater pressure switch or the water intake.
It could be that either the switch is faulty or circulation pump is blocked, you can check if the pump filter is blocked
Dec 18, 2010 | Miele Dishwashers
What does it mean when F 14 is displayed in the window?
F14 - "level/pressure switch failure." The level switch monitors the dishwasher's water pressure, as it circulates, which is especially critical, during the heating cycle (main wash). Level switch failure can commonly happen from poor circulation, or from the defective level switch, itself. The most common reason for poor circulation is low water fill level. In other words, during the water intake cycle, insufficient water came into the dishwasher. Observe if enough water did come into the dishwasher, Check the water level, by using the filter's handle (located on the floor, of the inside of the dishwasher) as a reference point. At the end of the water fill stage, the water level should be just underneath the filter's handle. If the water level is more than half an inch, below the filter's handle... then that could be a problem. The sympton would be a noisy, sluggish, whooshing sound of water, during circulation - It wouldn't be the same old quiet Miele dishwasher you knew.
If you have the low water fill problem, then look at the dishwasher's water intake hose. Miele call this their Waterproof System hose (WPS). It's a water hose with an integrated electric valve. First, shut your water valve that connects to this WPS; disconnect the WPS from your valve; look inside the end of the WPS. With a needle nose plier, remove the rubber seal, filter and the water restrictor; clean them of any possible debris; put all the parts back into the WPS, securely; reconnect the hose; open your water valve; and test the dishwasher. If the problem persists, then the WPS will need to be replaced (WPS~$170).
Other causes for F14, can be weak circulation from foreign item(s) (plastic wrapping, broken glass, etc,...) lodged inside circulation pump impeller, or no circulation, at all (circulation pump stuck). Of couse, the defective level switch, itself, can cause the F14, too. The least common causes for the F14 can be broken wires to and from, level switch and electronic unit, and a defective electronic unit.
Oct 18, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 is presenting after completing 75% of cycle, then the machine stops, this happens on all cycles
Hi dear.Please follow this if you can do it,other wise call service department.I hope that solves your problem.Thanks. F14
Water intake fault: Heater pressure switch
Cause:
Heater pressure switch B1/13 defective.
Remedy:
1. Check the heater pressure switch.
2. Check the connection plug and wiring harness.
3. Replace the heater pressure switch, if necessary.
Cause:
Circulation pump inoperative. Circulation pressure too low (no pressure at
heater pressure switch). Pump may be blocked by foreign objects.
Remedy:
1. Check the circulation pump for foreign objects.
2. Check the circulation pump capacitor.
Aug 18, 2010 | Miele Premier-Plus Built-in Dishwasher
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
1,674 people viewed this question
Top Dishwashers Experts
