Question about Neovo Computers & Internet
No signal monitor F-417
So I wanted to use a second screen for my laptop and had this old screen laying somewhere... and i thougth, i will just use that. But there was a small problem. My laptop didn't have a svgaport. So i ordered a svga to hdmi cable online, i screwed open the monitor, took out the old cable, put the new one in and I was finished. But if I want to connect it now to my laptop is says/ NO SIGNAL. The laptop recognizes the screen and show F-714 in the resolution window. Can anybody help me to fix this problem?
    Problem Solver:
  • 5 Answers
Screen has been identified and installed but you need to send laptop signal to this second screen
there will be a key on the keboard or you can right click the desktop then proceed to send signal to the attached second display
Posted on Nov 26, 2013
Testimonial: "i tried the Windowsbutton + P but the screens still says : No Signal... Any other solutions?"
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
samspelljr
  • 62 Answers
SOURCE: monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Posted on Jan 16, 2009
  • 63 Answers
SOURCE: Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Posted on Nov 02, 2009
SOURCE: hp w2207h screen in blank but flashlight shows icons are
The power supply-inverter board is probably at fault. Remove the back cover and locate the standard ac power cord connector. The board that the power input connector is soldered to is your power supply - inverter board. Check the electrolytic capacitors on the board. They probably went bad. A visual inspection is usually enough to find out which ones are bad. They will be either bulging or cracked at the top and leaking fluid. I usually replace all of the capacitors that have the same rating whether they look bad or not. Will save you another repair later. If the caps don't look bad, you can take the board to your local tv repair shop and have the caps checked with a esr tester. It's more accurate and they can be tested with the caps in place. Hope this helps.
Posted on Mar 08, 2010
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Screen broke on hp cq70 so I want to wire it to an old tube monitor
All you need to do is connect a monitor to the video port on the laptop, then power up the monitor first then boot up the laptop. The video signal will automatically divert to the external monitor first.
Dec 17, 2009 | HP Compaq Presario CQ70-120US Laptop
My Neovo f-417 LCD Monitor is switching off after 3-4 seconds. Green lamp is still blinking but there is no ligts and picture on screen. Only black screen
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Sep 23, 2009 | Neovo F-417 17" LCD Monitor
Found a Toshiba laptop, about 2 years old. Screen
at two years old it is basically exctinct already and the costs of laptops coming down so rapidly you can probably go on craigslist or ebay and find a cheap laptop that is working and ready to be portable. you can also try and sell the toshiba online for parts
Sep 02, 2009 | Toshiba Satellite A135-S4427...
I want to connect my new monitor to an older computer (6 years old 1.3 Ghz) and the monitor says only CHECK SIGNAL CABLE) I checked them already and they are properly connected. The same thing when I...
If you can successfully connect another (second) monitor to your notebook and the Flatron will not work in the notebook I would be suspicious that this new monitor has a problem. Check for bent pins in the connector.
If you have not previously connected a second monitor to your notebook use the Fn key and toggle the key on your notebook that switches between the notebook screen and the external monitor. (The key that has the image of 2 monitor screens, might be F4). If the new monitor then works it would point to a problem on the old 1.3Ghz.
Jul 09, 2009 | LG Flatron W2242P-SF 22" Monitor
CONNECTIING COMPAQ LAPTOP TO MY NEW 42"LG LCD TV
If the cable from the laptop is connected to the TV, you've selected the VGA input and see no signal, you probably haven't enabled the laptop's VGA output connector. Somewhere on the keyboard will be a function key with a little monitor screen on it. Hold down the F or Fn key and press the monitor key and it will switch on the external monitor connector. On some monitors, the first press shuts off the laptop screen when it turns on the external connector. If yours does that, press the key a second time to turn the laptop screen back on.
Feb 16, 2009 | HP Compaq nc6000 Notebook
External display not displaying!
When you are able to view a video clip on the external monitor, We can rule out the issue with the software. Probably you need to check the connections and also the external monitor settings in the display. The reload might have changed the old setup
Feb 03, 2009 | Dell Latitude D820 Notebook
How to use a sony tv as a monitor?
Change the resolution on the second monitor if you ont have the 2nd monitor on your pc , Clik ON DESKTOP PROPRERTY ,SETING'S amd see the 2nd screen rezolution. and make it smaler on the second ,you will be able to keep bouth screen active the monitor and the main screen of laptop.
Jan 19, 2009 | Toshiba Satellite A15-S129 Notebook
StudioWorks 700s Monitor No Signal
Try to connect the monitor to a different desktop/laptop, to see if it works at all.
Try a different monitor on your computer, to see if the video-card in your computer is the problem.
Or, spend $50 to $100 to buy a used 15-inch or 17-inch LCD monitor.
Sep 20, 2007 | Computers & Internet
Neovo F-417 failure
When troubleshooting another problem with this monitor i had it open and noticed that all thought this monitor has a "fixed video cord" once the unit is opened up it actually plugs in just like any normal video cable for a monitor. If the monitor video cable is the problem(bent pins, twisted to much, left kinked) then replacing it is an option. Simply open the monitor carefully(so as not to break any clips) and remove the EMI Shield. Once you do this you will be able to see where the video cable plugs into the monitor and replace it.
Jan 29, 2007 | Neovo F-417 17" LCD Monitor
Computers & Internet Logo
71 people viewed this question
Top Neovo Computers & Internet Experts
Tom Chichester
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
