Question about American Standard Heating & Cooling
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fan on and works again for a while
    Problem Solver:
  • 18 Answers
I have/had an American standard heat pump.
I removed it and will not buy another heat pump.
I've had several brands and the basic thing wrong is the design/concept/complexity trying to use same indoor coil (Evaporator) and expansion valve in two modes.
What has happened to yours, I think is the expansion valve failed in the heat mode and if left there will burn out the compressor.
Another thing is the reversing valve or the control card fails, but in other machines there is a safety pressure cutoff to save the compressor.
You notice when the is supposed to be blowing warm air, but it's cold. This is complicated by the timers for turn on and shut off, so when you observe you can't be sure what's happening.
By this time you have replaced it, so just for info, I think to avoid heat pumps. Think about it. The compressor will be running all year instead of maybe 7 months for cooling. That alone shortens it's life.
And if the temp gets to 40 deg continually, you will be using strip heaters anyway. Some show when "emergency" is on.
Another thing is sizing the unit. Most suppliers will suggest a size for cooling, when in fact you may need say 3 tons for the 1.5 tons heating you will get in the winter. IOW, you're buying a much more expensive unit when you only need maybe 2 tons of cooling.
It depends on the humidity and number of occupants more than building size.
I can and maybe you can run with the equivalent 1 ton heating strip heater, i.e., 4 kw, and install a cheaper unit with a lower EER, say 13, instead of 15. And you get one that is really more reliable because of less complexity. Also the 13's have been around longer, therefore better experience. And they are quieter - smaller fans.
I have come to the conclusion that the high EER machines do not justify the higher cost.
This after 24 years and 8 A/C's of various makes in this location.
Posted on Feb 02, 2015
    Genius:
  • 1,198 Answers
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
Posted on Nov 27, 2013
  • 1214 Answers
SOURCE: rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Posted on Jan 27, 2009
  • 10 Answers
SOURCE: Heat Pump Reset Button
If running in heat check indoor air filter if in cool wash out outside coil with garden hose make sure fan is not overheating and shutting down.
Posted on Jan 08, 2008
SOURCE: Amana Heat Pump Emergency Heat will not come on
On the heating element [behind the coil, (the springy thing)], at the top end of the element, there is a little thermistor I think it is called. You will have to remove the fan shroud. With the power off, check for continuity if you have a multimeter. If that is the problem (no continuity), you can pick one up at al local heating supply. Just have it soldered back in and reconnect. If the thermistor 's continuity is okay, remove the main board under the control knobs. I have seen these boards burn in the back where the relays are soldered on. If you're really good with a solder you can try to re-solder it. If not, it's about as cheap to buy a new unit as it is to buy the board. Good luck.
Posted on Feb 17, 2009
mastatech
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
daddyo742001
  • 70 Answers
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Posted on Jun 28, 2009
Heat works until thermostat calls for aux heat, then blower shuts off with outside unit still running.
Some blowers shut off depending on the system. Do you have electric hest strips inside? If not the blower will shut off. The outdoor fan should not be running if in defrost mode. If you have heat strips then you likely have low voltage wiring crossed
Dec 16, 2016 | American Standard Heating & Cooling
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
American Standard heat pump troubleshooting
If the compressor is not frozen, then it is most likely one of the starting capacitors on either the compressor or the fan motor. These can fail without warning and without any outward indication. They are shaped like small cans or oblong cans and have 2 or more wires that attach to them with terminals. If you are going to remove one or check them, Make sure the power is off first.
Aug 11, 2014 | American Standard 282999 4" Heat Pump Snow...
A/c fan not blowing
Possible bad fan or it is not being turned on---time for a tech to look before it gets worse.
Aug 30, 2012 | American Standard 282999 4" Heat Pump Snow...
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Jan 11, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Mar 11, 2009 | Heating & Cooling
Rheem heat pump. blower will not turn off
Jan 27, 2009 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
Pete Norton
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
