Question about 1A Auto Parts 2007 Chevy Kodiak C4500 Mass Air Flow Sensor Meter for V8 8.1L
2007 c4500 2wd front spindle nut torque and specialty socket to do so?
What size socket do i need to fit axle nut on a 2007 dodge caliber?
I told you already 22mm. It was a guess, but it was right!!
http://www.oreillyauto.com/site/c/search/Spindle!s!Axle+Nut/01232/C0362.oap?year=2007&make=Dodge&model=Caliber&vi=1433273
Dodge Caliber 2007, Front Spindle Nut by DormanĀ®. Thread Size: M22-1.5. Packaging Quantity: 5. Packaging Type: Box. Dorman's Spindle Nut is manufactured for high corrosion resistance and a long service life. Depending on the...Direct replacement for a proper fit every timeHigh quality steel construction more details on -
https://www.carid.com/2007-dodge-caliber-driveline-axles/dorman-spindle-nut-31531756.html
axle nut on 2007 dodge caliber Google Search
Jan 22, 2017 | Dodge Caliber Cars & Trucks
07 equinox wheel bearing torque
Front wheel bearing torque on the spindle nut is 151 ft. lbs.
Sep 04, 2016 | 2007 Chevrolet Equinox
What size is the axel nut on a2006 chevy cobalt front
memory serves says 36mm.....not absolutely pos. though
Dec 14, 2014 | 2006 Chevrolet Cobalt
Socket sizes for the front spindle nut,lower ball,joints outer tie rods 2014 Honda accord V6 touring
it depends on if they have been changed before. normal size is 18mm changed is 19mm on tie rods. also check the condition of the anti-roll bar rubbers as they can cause this problem to. also check the traling arm on the steering this can do this to.
Feb 12, 2014 | Honda Accord Cars & Trucks
Manual free
Do the nut up until the wheel stops spinning, then back it of 1/2 to 3/4 of a turn, the nut should still be contacting the washer, fit the split pin from there, the wheel should spin freely.
Jan 12, 2014 | Yamaha 2007 Big Bear 250
What is the axle torque settings on the front an rear axle bolts on a 2007 ktm 250 xc?
Thank you for contacting FixYa with your inquiry.
I have compiled a list of all the useful KTM torque setting that apply to your bike.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber botton bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nutes on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
Let us know if we can provide further assistance.
Best regards,
TF
Jul 05, 2011 | KTM 250 XC Motorcycles
How to remove front spindle nut on a 2000 Oldsmobile Bravada
The 2000 Oldsmobile Bravada spindle nut is 36mm, and the Torque specification is 203 ft-lb.
To remove the nut you need a very powerful impact drive, or 1 inch drive socket tool.
Oct 10, 2010 | 2000 Oldsmobile Bravada
Cannot find tool to loosen front wheel bearing lock nut
I have a 1995 Geo Tracker 4WD with the same exact problem,However I did some research . You will need to go to the Kent Moore Website which makes specialty tools and look up Wheel bearing socket "J-37763" I saw the picture of it and it looks like there are 4 small rounded teeth/tabs. Unfortunately get ready to spend some money - cost is about $70.00 not including shipping/handling
I hope that this Info. helps - Jim H.
Apr 06, 2009 | 1995 Geo Tracker
1A Auto Parts 2007 Chevy Kodiak C4500 Mass Air Flow Sensor Meter for V8 8.1L Logo
529 people viewed this question
Top 1A Auto Parts Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a 1A Auto Parts Measuring Tool and Sensor Expert? Answer questions, earn points and help others
