Question about Neato Brand PhotoMatte Jewel Case Insert / Tray Liner Sheets - (CIP-192382) Media (100 Pack)
HOW TO PRINT NEATO CD CASE TRAY LINERS
Would like to know how to prepare neato jewel case insert tray liners with spines
app_3rp22205
  • 3 Answers
SOURCE: My neato won't map, just
Make sure you have upgraded to software version 2.6:http://neatoroboticsupdates.com/
Joewww.joeramsay.ca
Posted on Feb 26, 2012
app_3rp22205
  • 3 Answers
SOURCE: using neato in a new
Make sure you have updated the on-board software to the latest version, 2.6.
Joe www.joeramsay.ca
small6363
  • 18402 Answers
SOURCE: wondering where I could obtain a schematic for my neato xv-11 all floor vacuum system.
this link is for the manual may help you..
http://www.roboshop.lt/wp-content/uploads/2012/05/neato-xv-11-user-guide.pdf
Posted on Dec 08, 2012
mdstarks99
  • 20 Answers
SOURCE: my neato is showing a message :my vision was blocked. please press ok (3000). How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop
sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
Posted on Sep 26, 2014
Neato botvac connect does not return to dock
If it's still under warranty, the best thing would be to call Neato support. There is also a very active Neato support forum on the site robotreviews [dot] com where you will find many experts who own Neatos.
Apr 25, 2017 | Neato Vacuums
My Neato XV1 says it's vision is blocked. I have cleaned everything-used pressure air, wiped off all vision eyes but it still says it's vision is blocked. What else can I do?
There are several errors that can occur for unknown reasons if your batteries are not working properly. How old are the batteries? There is a piece of software designed by Neato users which can diagnose issues with your Neato, including getting a map of the lidar scans. Search for the download on the site robotreviews [dot] com in the Neato forum.
Mar 30, 2017 | Neato Vacuums
My Neato XV-12 runs for only a few seconds and stop. The message says, please dust me off I cant see. I have dust and cleaned my neato and it still says the same thing. How do I fix this problem?
Hi Guys
I've fully dismantled my Neato XV-21 to locate the source of the "can't see" problem. (And also replaced a tight wheel Motor causing a "something is caught in my right wheel" message)
There several screws underneath the Neato XV-21 that must be undone to allow the top to be separated. A bit of a pain just to get into the visual sensor area. But not too hard with an electric screwdriver.
There is a Laser device & a Photo sensor mounted to a black plastic rotating wheel which is covered by a black cap with 2 holes in it. One hole for laser beam to exit & one to pick up return laser light return data. They are both rotated by a motor & pulley via a rubber "o" ring which could slip, break or get hairs caught in it.
These could be the source of problems. Once mine was cleaned & checked I had no more problems. Then the wheel motor got tight. Replacing the motor fixed the problem. This requires hoping the Motor Gear Box assembly out by poping the pivot shaft out of it's plastic holder. Then disconnect the spring & cable connector. But you bust be prepared to carefully remove the magnet off the motor shaft (vice & 2 flat blade screw drivers) then unsolder the small PCB at 2 points. With practice (twice) I can now replace a motor in 20-30 minutes.
Hope this Helps some Neato Users out there
Cheers
Trevor
neato-xv-12-runs-only-few-seconds-stop-qnpe3nojpvl4vx0tieerofmg-2-0.png Wheel Motors Here
Wheel and brush motor for Neato XV 11 XV 12 XV 14 XV 15 XV 21 XV Signature...
Apr 05, 2015 | Neato Robotics XV-12 Vacuum System - White
Neato won't charge
Hi, it's Jeremy from Crucial Vacuum.
Try charging your Neato vacuum directly with the plug. If you take apart the dock you will find the plug inside. Plug that plug directly into Neato and charge the Neato until its light is green. If your Neato's Battery charges and it works ok, reassemble the base with the charger making sure that the plug you plugged into your Neato is plugged FIRMLY into its connector inside the base.
You can purchase direct your replacement Neato parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=neato&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Neato Vacuums
Neato vacuum display will not come on.
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jul 04, 2014 | Neato XV11 Vacuum
Why does my neato xv-12 keeps saying "put me on the floor" but it is and I cannot turn off
There are sensors in the wheel housing that let Neato know whether it is being held (wheels protruding from the frame), or whether it is on the floor (wheels tucked into the frame). If those sensors are not working, you will need to have the unit serviced (if under warranty), or you can look up information on how to correct the problem yourself (if out of warranty). This information can generally be found by searching the Neato Robotics forum at:
RobotReviews com
May 11, 2014 | Neato Vacuums
Need replacement drip tray liners for Thane Q Grill
I have several boxes of replacement foil trays for the Thane Q Grill. email gary@firstchoicemusic.com
Sep 23, 2012 | Thane Q-BBQ Grill
I have a photosmart d5363. battle to print on a printable cd.how do i calibrate from working from media face. 762438@yebo.co.za
Part of the Neato software is a calibration function (It is on the installation disk)
You run it and it prints out a chart which tells you how far out your printer is
You then change some values on the setup to suit the mechanics of your printer and it should be in line
I use Neato and find that even with a machine that is supposed to be lined up I get overprint
It is easier to make your layout then make a print on paper using a dark colour , lay this on top of a CD and see which way the machine drifts.
You can then drag the image around on the Neato scream to make sure that it is in the right place before you print a CD
Jun 04, 2009 | HP Office Equipment & Supplies
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
CD Covers
What's Up Sparky? What is number of the cd paper you are using? Should be something like 'Neato Fellows VS-101-XXX-XX'? Or 'Avery 86XX'?
Jun 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Neato Brand PhotoMatte Jewel Case Insert / Tray Liner Sheets - (CIP-192382) Media (100 Pack) Logo
23 people viewed this question
Top Neato Electronics - Others Experts
Are you a Neato Electronics - Other Expert? Answer questions, earn points and help others
